4x4 VS 4x2... What is turning?
#31
#36
#37
sorry i just dont see it your way but for argument sake we'll agree to disagree and you can get back to kissing you clunky vacuum hub, death wobbling, driveline vibrating... err i mean far superior running gear. good day sir
oh ya one more thing before i say adios, other day i was watching 4x4 truck pulling league and 90% of them were using cummins engines. shocked the hek outta me since powerstroke is supposed to be such a brute. i guess not when it comes to competion pulling
Pulling a sled 200 ft has nothing to do with longevity of ball joints or housing strength. Most of those trucks have 3 grand dumped into RCVs and cryo gears. You try bumping down my road 6 days a week in a Ram, and have ZERO problems over 180,000 miles(when I finally replaced my joints), then I'll respect your opinion.
The problems you speak of are usually present on the first page of the 2013+ Cummins Forum, and threads are well over 1000+ posts. Last I heard, aftermarket companies weren't swooping down to offer a bulletproof ball joint due to premature failures at 80 50 heck even 30K miles on Ford trucks, only Rams.
A bit confused why engines matter in a thread about 4x4 running gear? I'd be using a p-pumped Cummins also due to easy hp gains if I was sled pulling. So what>?
#39
It's mostly disappointment. I don't like any company having a monopoly on my business.
GM is retarded, and Dodge is just a cheaper crappier Ford.
At least if I was into little trucks I could choose for the overpriced Colorado, the even more expensive Zr2, Tacoma, Frontier, New Ranger, etc. etc. HD trucks? Nope. The Ford XL and XLT stomp them all pretty badly right now.
#40
I agree with the Make debate
I have just recently purchased a Ford 350 XLT Premium Package which I traded a 2009 Dodge Ram 2500 in for. The Cummins in the truck was great. Within 6K miles i already had a ball joint failure on drivers side front axle. I could lift front tire up while jacked up by 3/8" of an inch. Dealer said was in spec so SOL for warranty. The ball joint being that loose caused a vibration at highway speeds. I went on to replace them twice myself. I also had to replace track bar for the beginnings of a death wobble along with steering damper. The truck steered like my dad's 1971 Ford Explorer from 6K to 178K and the time i traded it. Then I went on to install a free spin kit which led me to notice slack in the ball joints on the tie-rod and lower drag link ball joint. I upgraded those as well. Transmission never shifted right it seemed to lug or to shift too late, but luckily never failed, just irritated me. Transmission temps would go off the chart when i was pulling the RV in summer, always worried me. I had to replace batteries at least once a year. Wiring harness had manufacturing defect in rear drivers door window that pissed me off so bad i had all but completely destroyed the door panel before finding it. All in all the motor was great and run like a raped ape with no issues ever but after crawling under the 2017 Ford with the new frame and heavy duty steering components and tight driving that is all that it took. Not to mention the power...
#41
not to shine a light on this guy but his '17 f250 front end components needed replaced at just 24k, mostly all highway miles. https://www.ford-trucks.com/forums/1...th-wobble.html
#42
sorry to hear your bad luck. maybe you had a lemon ? it happens from time to time.
A 'lemon' is defined as a vehicle with an anomaly defect not normally experienced with other vehicles of the same type/brand, and not corrected within three service attempts.
The Ford you referenced, that is the proper definition of a lemon. Out of the millions of Dana 60s produced for these trucks, a small percentage will be jig welded with incorrect caster angles. It happens.
