need help with ser number
Old Sep 14, 2003 | 12:23 AM
cobraii's Avatar
cobraii
I hope some one can help me decode this one
1992520L4-174397B
trim 04
paint cc
engine rr-4spd
I somone could help it would be awsome?
Old Sep 14, 2003 | 06:35 AM
banjopicker66's Avatar
banjopicker66
We here are very happy to help, but that VIN looks like it needs to be posted in a different forum.
Old Sep 14, 2003 | 11:58 AM
cobraii's Avatar
cobraii
It is the vin number off my truck and I wanted to make sure if it was a 63 or a 64.
It has a really weird option group on it.
Where do I find the waranty plate?
Old Sep 14, 2003 | 01:27 PM
banjopicker66
Your VIN is not a '60s vintage number for F-series trucks.
The warranty plate will be found in one of several places: the drivers door below the door latch, inside the glovebox, or alongside the radiator on the radiator support frame.
The VIN (not the warranty plate info) can also be found stamped onto the frame, on the passenger side, along about where the engine perches sit.
Old Sep 14, 2003 | 04:17 PM
cobraii's Avatar
cobraii
help. the truck sure looks like a 64
check my gallery I just added some picts of the truck.
and one of the ser plate.
Old Sep 14, 2003 | 04:41 PM
johnsalterego's Avatar
johnsalterego
The grill is a '64, but it could have been swapped out when the fender was changed (they would have had to drill extra holes to make a 64 grill fit on a 63 - I have one of each and know for a fact the grills don't mount up the same) The plate 'looks' 66-ish, but Banjopicker is right about the numbers not matching up. Here is decoder site that works well: http://home.earthlink.net/~jcpurut/vin/vin.html Two things come to mind on yours: Where was the plate located - Is it located on a part that could have been swapped from another truck? And since it's a Mercury truck and not a Ford I wonder if the codes are different?
as an afterthought by looking at the one side-shot, the bed appears to be one of the 61-63 miss-matched ones...
I think you have a mystery mutt on your hands! It should still be a fun toy...
Old Sep 14, 2003 | 04:48 PM
banjopicker66
banjopicker66
Old Sep 14, 2003 | 04:49 PM
johnsalterego
The link I posted has pictures of all three different plates installed from 61 to 66...
Old Sep 14, 2003 | 07:48 PM
cobraii's Avatar
cobraii
I just updated the gallary with more clearer pictures.
I just unloaded this truck yesterday morning boy it sure looks like fun in some mud.
Old Sep 15, 2003 | 09:43 AM
Mike G's Avatar
Mike G
I believe the VIN plate is correct, however the Mercs have a little different coding system. There was a post a while back on decoding a Merc, check to see what you come up with and I will dust off the memory and see if I can find something.
--Mike
Old Sep 15, 2003 | 05:06 PM
Mike G's Avatar
Mike G
Mercury and Canadian... Try this out, maybe someone can shed a brighter light than I.
www.mercurytrucks.com
--Mike
Old Sep 15, 2003 | 11:21 PM
cobraii's Avatar
cobraii
I tryed them And still no match. but alas I think I will call it a 64 and just drive it Thanks for the help.
Old Sep 16, 2003 | 08:29 AM
banjopicker66
Give this a try: On the frame rail, somewhere about where the engine mount is, you should find the VIN stamped into the top of the rail.
Try cleaning that up with a wire brush, try to find it.
That VIN may be slightly different in style, perhaps without the 1992 for example, and may therefore present a clearer picture of your truck.
If you look at the last 6 digits but ignore the B, you appear have a May '61 truck on your hands - which doesn't make sense.
Sorry I cannot be of any further help, but if you discover the frame VIN, and learn it is in any way different, post back.
Old Sep 16, 2003 | 07:42 PM
cobraii's Avatar
cobraii
I found another plate under the hood on the firewall the numbers are
024032
CC 75
024032 1992520 L
Check my gallery for the picts of it
