Running light out
Old Jan 9, 2018 | 09:18 AM
Darrellt's Avatar
Darrellt
Running light out
Hi folks,
I've searched the forum and turned up little. I have a '66 F250. Both brake and turn signal lights work. The running light on the passenger side is out. I swapped bulbs and they both work fine. I inspected the wiring from the tailgate to the engine compartment and don't see anything obvious. Any tips on how to proceed? Why would brake and turn signal work but not running light? There are only two wires. I'm not a stable genius with electrical so I'm stumped. Thank you kindly.
Old Jan 9, 2018 | 09:55 AM
Crop Duster's Avatar
Crop Duster
I would start by removing the tail light housing and cleaning up the connector. I believe the brown wire is for the tail light. Make sure the springs under the bulb contacts are free. You only have two wires because they ground through the bed.
Old Jan 9, 2018 | 10:12 AM
Darrellt's Avatar
Darrellt
I did that. The springs did seem kind of stiff. I'll use the meter and check the wires at the connection next. It's got to be a ground issue I'm guessing.
Old Jan 9, 2018 | 10:16 AM
thrifty's Avatar
thrifty
Try getting an external ground and ground the housing for a test. Crop duster hit the nail on the head. Make sure the pig tail connections have a convex shape and making contact with the bulb.
Old Jan 9, 2018 | 10:18 AM
Darrellt's Avatar
Darrellt
It looked pretty worn down. Are there replacements for these housings? Junk yard I suppose.
Old Jan 9, 2018 | 10:24 AM
thrifty's Avatar
thrifty
Napa sells them. Just ask for tail light pig tail, usually comes with a spring. When the light is in place push up on the bottom of the wire to engage the connection. Sometimes not being in the housing correctly will cause it not to work
Old Jan 9, 2018 | 10:25 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I've used my soldering iron and built back up the solder on both the connections and light bulb bases with success before - if you already have a soldering iron its worth a try. The solder is somewhat soft and with the spring pressure it wears almost constantly as the truck is bouncing down the road.
Chad
Old Jan 9, 2018 | 10:30 AM
Darrellt's Avatar
Darrellt
Great minds think alike. I was thinking a blob of soldier might do the trick as a temp fix anyways. Thanks for the tips Thrifty.
Old Jan 9, 2018 | 10:40 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I would definitely use solder instead of a blob of soldier. I was a soldier in the 82nd Airborne Division so I speak from experience here. Trust me....lol.
Chad
Old Jan 9, 2018 | 11:29 AM
Darrellt's Avatar
Darrellt
Hahahha. Good point.
Old Jan 9, 2018 | 11:31 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Sorry, couldn't resist.
Old Jan 9, 2018 | 09:48 PM
Darrellt's Avatar
Darrellt
Okay so here's what I know. I ran a ground wire from the battery and checked each connection. One I got a trickle of a reading, the other, the gray lead was dead. I checked the first connections further up the line and it was inconclusive as I couldn't get a good ground there. I check the connection where it splits off in the engine compartment and reading was strong. I'm guess a broken wire at this point but where? There's a whole ****e load of electrical tape to undo just between the connection in the rear of the truck to the tail light. I'm thinking of running a good wire form the connection at the rear to the dead tail light connect to see if it at least lights at that point before unraveling all the tape. Ugh.
Old Jan 10, 2018 | 05:17 AM
Crop Duster
Wiring
I would check the connectors in this picture. You only have three wires at the connector by the steering column. So you have power to this point if as you say you have one tail light working. Unplug these connectors, turn your lights on and use your volt meter to check for power to this point. That will tell you which harness has lost connection. I would suspect corrosion in one of these connectors.
Old Jan 10, 2018 | 10:25 AM
Darrellt's Avatar
Darrellt
Ah yes. Those are the guys I failed to get a decent reading on. Will attempt again this weekend when I have more time. I did hit one with a file to clean it up a bit. I need to do the other as well. Boy, I really hope this is the issue. Thank you kindly.
Old Jan 10, 2018 | 12:05 PM
Crop Duster
I found the easiest way to clean those female connectors is to roll up a piece of 220 grit paper and spin it between your fingers. When you plug them back up put some silicon dielectric grease on them to keep them from getting wet and corroding again.
