Help! 7.3 idi troubles
Old Jan 8, 2018 | 10:02 PM
Leighton's Avatar
Leighton
I've got a '93 f350 4x4 7.3idi with injector problems. It was parked over the summer with bad clutch, after remain injectors installed.(<1500 on install). Get it back Wednesday drive maybe 100 miles, starts popping like exhaust leak,but no joy. Pop hood, its coming out factory airfilter.
This is with full fill up, no additives. Now I'm low on go juice, fill up + stp injector treatment.
Please, any suggestions?
Old Jan 10, 2018 | 08:35 PM
DrCharles's Avatar
DrCharles
Valves sticking in the guides?
Old Jan 10, 2018 | 08:48 PM
Leighton's Avatar
Leighton
I've pulled valve covers, while running. 1 rocker was moving 1/8-1/4" less than others. Pulling lifters Friday & will inspect pushrods at same time.
Possibility of of popping back on power stroke?
Old Jan 10, 2018 | 08:51 PM
DrCharles's Avatar
DrCharles
If that's not all that's causing your problem, it is certainly suspicious This engine doesn't have a high-lift cam to start with.
I hope you haven't wiped a cam lobe. If lucky, just a lifter collapsed or gummed up.
Old Jan 10, 2018 | 08:57 PM
Leighton's Avatar
Leighton
128k & change, factory. Any upgrade EOM. Surprised if lobe dropped, hoping just lifter.
Any suggestions on reloading new lifters?
Oscar Gamon
Aug 21, 2019 03:15 PM
97Fordf35089f250
Feb 7, 2016 10:20 AM
Ibuildembig
Dec 22, 2012 04:08 PM
Highmark18
Jan 19, 2006 01:11 AM
