snowplow size
Old Jan 7, 2018 | 07:22 PM
adventuris's Avatar
adventuris
snowplow size
ordering new truck 250 ccsb with 6.2 4.30 , looking to put on a vplow what size are people running .
Old Jan 7, 2018 | 07:58 PM
USSenator's Avatar
USSenator
Get a F350.
I used a Boss Poly V. 8' 2" in my 03 F350.
Old Jan 7, 2018 | 08:08 PM
J Standard's Avatar
J Standard
Depends on what you are plowing, for contract work and plowing your own places I would go 8.2, if doing rural drives and roads I would go 9.2, the truck would handle both with ease.
8.2 folded in is only a few inches wider then the truck so easy to drive and park with.
I hate poly plows! They crack, break, fade, and are HEAVIER then steel!
Don't even bother to try and plow with the stock tires, get them swapped out before getting plowed installed so they get the mount height correct.
Old Jan 7, 2018 | 08:11 PM
Snowman 8's Avatar
Snowman 8
I have a 9’2” steel boss V plow that I have had on my last 3 F350’s. I haven’t gotten around to installing it on my 17 yet but it will be on there in a couple weeks. After having a 9’2” I wouldn’t go any smaller, the F350 handles it just fine. It’s been on a 2001 F350 CCLB, 2006 F250 SCSB, and a 2011 F350 SCLB and next a 2017 F350 CCLB.
Old Jan 8, 2018 | 03:37 AM
doucetrr's Avatar
doucetrr
Do you have a specific reason for wanting a V? I've had Fishers for 30 years. In their applications, they run approximately a thousand bucks more than a straight blade. More moving parts to fail, and I understand the cutting edges are very expensive also. I just don't see the upside unless it's a commercial application. I am putting a 9' straight blade on my F-350.
J Standard, what is wrong with stock tires? Mine came with Wranglers, I intend to run them....
Old Jan 8, 2018 | 04:46 AM
rwilimo's Avatar
rwilimo
I'd suggest a minimum of an 8.5' on these trucks or else you will be running over snow, I installed a 8.5' Western MVP 3 and it is a very nice upgrade over a straight blade
Old Jan 8, 2018 | 06:58 AM
crewzer's Avatar
crewzer
Lightbulb
The 2017 SuperDuty eSourcebook also provides guidance on snowplow applications; see pages 66-69.
HTH,
Jim / crewzer
Old Jan 8, 2018 | 07:26 AM
USSenator's Avatar
USSenator
In 15 years, I never had a crack or break in my poly V plow. They do fade a bit, but do not rust. The frame rusts though, and they are heavier because the frame is beefier.
I used Goodyear Silent Armour tires. It was an ice/snow tire and had some serious traction in the snow.
Old Jan 8, 2018 | 07:35 AM
Snowman 8's Avatar
Snowman 8
I have had my Boss 9’2” V since 2001 and never had a problem with it other than a couple solenoids on the truck side of the wiring. If you are plowing rural driveways they are far superior than a straight blade! When the snow is deep you make the first pass down the driveway in the V position and widen it out from there. They also work very well in bigger ares when you need to carry snow because you can push both wings forward into the scoop position. When I had a straight blade there would be times that I could not push my way down some of the long driveways that I plow because of deep drifts causing the plow to push the back of my truck sideways and getting me stuck. Since I have had my V I have never had to give up on a driveway and go back for a skidloader or tractor to bust a driveway open.
The only moving part that a V has over a straight blade is the center hinge and there is nothing there to fail. Give it a few shots of grease a year and your golden, or forget to grease it for a few years like I have and your still fine!
Old Jan 8, 2018 | 09:15 AM
yamaguy's Avatar
yamaguy
Originally Posted by USSenator
Get a F350.
I had to look and make sure I didn't post this as I was reading it... I had a Boss 9'-2" poly v on my 2003 F350. It was an amazing plow and never let me down plowing commercially. As others have said having a v plow and being able to not just bust a trail (something I rarely needed), but being able to put it in scoop mode and actually carry snow and not just defelect it is amazing. Leaving it half straight and half angled so that you can carry more snow and not just windrow all of it it great as well. I'll never own a plow that is not a v again. And like others have said the only other moving part is a hinge and even if the cutting edges are a bit more expensive the productivity makes up for it many times over. My cutting edges lasted a few years.
Old Jan 8, 2018 | 09:59 AM
J Standard's Avatar
J Standard
Boss doesn't come in 8.6, it comes in 8.2 and 9.2, the 8.2 clears the truck width in every configuration/angle.
Old Jan 8, 2018 | 10:42 AM
Mgjfam's Avatar
Mgjfam
Get a 9.2 V plow---here's the reason.
The width of the V plow is clearing a "path" for your truck to travel....narrow plow/narrow path. When you plow very deep snow with heavy/icy/chunky stuff....the ice chunks CAN roll back and dent the side of your truck if the plow is not wide enough.
I had a 9.2 Boss Poly V plow on my previous truck - a dually (wide width is mandatory with a dually). The 9.2 just barely opened up a path for the width of the rear duals.
For my new F350 (single rear wheel)---I bought another Boss 9.2 Poly V plow because I don't want a small iceberg hitting the side of my $70,000 truck!!
Boss makes a great plow--never had a problem with them. Get a V plow if you'll be getting into deeper snow.
Old Jan 8, 2018 | 04:53 PM
adventuris's Avatar
adventuris
sounds like the 9.5 will not be to big , guess i will go with that , just have to deciede what manufacture now
Old Jan 8, 2018 | 05:24 PM
17F350's Avatar
17F350
I have the Boss VXT 8' 2" for smaller driveways but I also have the removable wings that give about 18" total extra width. They work great for larger spaces and for winging back the banks on camp roads when they start closing in. That way you can have the best of both.
Old Jan 8, 2018 | 11:06 PM
Pinky Demon's Avatar
Pinky Demon
Nothing smaller than 9’. When a V-Plow is fully Vee’d up, it is less than 7’6” wide, same as if you are scooping. When you plow, you want to clear snow as far away from your wheels as possible and you just cannot with a 8 footer. Not to mention when you go to turn.
Unless of course you are planning to always run wings, which in that case, get the 8’ 2”. A 9’2” becomes too wide to effectively scrape with them fitted unless you have a perfectly flat lot.
