9 f350. 460 engine
Old Jan 7, 2018 | 12:13 PM
Crazygspguy's Avatar
Crazygspguy
9 f350. 460 engine
Ok. Another question. I’m sure this was an emission part that was removed but it goes to the intake area. It has a huge amount of suction but Truck runs perfect aside from the high idle. (1200 or so most times). I’m guessing I should plug it off but am wondering if this could be the soft brake pedal issue?
Old Jan 7, 2018 | 04:44 PM
Red97350's Avatar
Red97350
Is that possibly for the thermactor system? It's hard to tell where the other end of the tube goes.
Red
Old Jan 7, 2018 | 04:49 PM
Crazygspguy
I’ll try to get a picture of where it goes up on the engine. I’m just surprised by how much suction it has and the trucks runs so smooth. I got a rubber plug to stick in the tube to hopefully stop the leak. Like I said. I’m new to these Fords.
Old Jan 7, 2018 | 05:16 PM
Conanski's Avatar
Conanski
Is that drivers side rear of the engine? If so it could be EGR and if that is correct then you wil have a massive air leak at the EGR valve every time the valve opens.
Old Jan 7, 2018 | 06:31 PM
Crazygspguy
Yes it is. I took a couple pics tonight. I’ll try posting. I did get a neoprene plug I plan on putting in it to stop the leak. My brakes feel very soft so I’m wondering if this could be the issue. It also has no converter on truck. It’s been bypassed before I got it. And on the right fender there’s 2 things that are blowing air as it runs. I’m guessing the air pump.
Old Jan 7, 2018 | 06:38 PM
Crazygspguy
It goes right to this. The rusty pipe underneath is the one that has been cut
Another view
Old Jan 7, 2018 | 07:05 PM
Red97350's Avatar
Red97350
That would be the EGR valve.
Red
Old Jan 7, 2018 | 09:47 PM
Conanski's Avatar
Conanski
Yes, so you need to either replace the EGR tube or insert a piece of metal in between the valve and intake to prevent fresh air getting in.
walperstyle
Oct 24, 2016 06:24 PM
Leisa Wilson
Jun 6, 2015 07:34 AM
SoCar72
May 18, 2010 07:47 PM
bizzy1
1983 - 2012 Ranger & B-Series
Feb 6, 2005 09:48 AM
