I'm upgrading my 83 300 to serpentine belt setup. Is there any difference in harmonic balancers? Other than the obvious difference, will the serpentine setup just bolt on? I have a 92 parts truck with everything I should need.
What you should do is try to be helpful and keep your worthless suck shut.
Your attitude is not appreciated and will not tolerated.
If you don't like someone's answer, don't use it. But being rude and personally insulting is going to get you banned from the forum.
I don't appreciate your attitude eaither, if you can't be constuctive, move on.
What *exactly* did you not understand about what I said?
People on these forums are only here by giving their own time. No one is required to help anyone. If you don't like someone's answer, then don't use it, and move on. But do not be insulting and rude. It is not tolerated.
