92 E4OD replacement ?
Old Sep 13, 2003 | 09:53 PM
coloradotoy's Avatar
coloradotoy
I have a 92 4x4 f-150 with the 5.8L and a blown E4od trans. I want to put a used one in it. my question is will any e4od work or dose it have to be one out of a 92 f-150 with the 5.8l?
Thanks
Old Sep 13, 2003 | 10:10 PM
ecarter50's Avatar
ecarter50
Any year 4wd E40D should work. The bellhousing is the same for 300, 302, 351w.
Old Sep 14, 2003 | 07:37 AM
pfogle's Avatar
pfogle
be carfull, in '95 the changed the MLPS (Manual Lever Position Switch)(neutral switch) to a different connector.
Old Sep 14, 2003 | 07:58 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Junkyards have extensive cross-reference information. Good Luck.
