2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
What did you do to your Superduty today? 2018 version.
Old 01-21-2019, 12:52 AM
ka_EMT's Avatar
ka_EMT
ka_EMT is offline
Added a set of LED pods to the rear bumper. Hooked up to my lighting controller. Not bad for $15 Ebay pods. Will do for now until I throw a set of Baja Designs S2s on it.
  #482
Old 01-27-2019, 04:12 PM
Gazoo2010's Avatar
Gazoo2010
Gazoo2010 is offline
Added Baja designs squadron sports. The amber lights are hooked up to upfitter number 1 and the white are plugged into the factory fog wires. Much better light output.... ~S
  #483
Old 02-01-2019, 12:25 PM
Ltripreno's Avatar
Ltripreno
Ltripreno is offline
Stainless steel rocker panels
Installed my Christmas present....ICI Stainless Steel rocker panels
  #484
Old 02-28-2019, 11:22 AM
bigred460ci's Avatar
bigred460ci
bigred460ci is offline
F350 6.7 SCLB
Airbags, Loadlifter 5000 #89399 with Wireless Air #72000
Stableload #A7311S.
Ordered the stainless kit, surprised to see that only the wedges were stainless, rest of the hardware wasn't. I also rented the Drill Tool, glad I did, I believe it made the task easier. The website said I would receive 4 drill bits but I only received two. After two holes the first bit was toast, so I was careful with the second one, drilled enough until it dimpled on the other side and stopped. Finished the holes up with a bit that I had purchased for the project. Used cutting oil as recommended. Had to unbolt the exhaust and move out of the way to get the tool on the rear of the passenger side spring.
Looking forward to spring to try out with the truck camper.
  #485
Old 02-28-2019, 12:00 PM
mtl-biker's Avatar
mtl-biker
mtl-biker is offline
Thanks to the knowledge and ingenuity of the members here I was enlightened to the hammerlocks to fix the poor design of the Ford factory hitch insofar as the holes for the safety chains are concerned. Also, kudos to the member who suggested putting them together on the bench first. They seem to go together a lot easier on the truck that way. Problem solved. One less thing to worry about while towing.
Hi
Wheres did you bought the hammerlocks
Thanks
Mario
  #486
Old 02-28-2019, 12:17 PM
BowtieConvert's Avatar
BowtieConvert
BowtieConvert is online now
Received 2,551 Likes on 835 Posts
Originally Posted by mtl-biker
Hi
Thanks
Mario
Hey Mario, I got these from Southeast Rigging here in Jacksonville. They sell slings, chain, wire rope, blocks, etc. Pretty much any industrial supply house should have them. They work great for the large hooks.
  #487
Old 02-28-2019, 12:23 PM
mtl-biker's Avatar
mtl-biker
Thanks its 1/2 or 5/8??
Mario
  #488
Old 02-28-2019, 12:40 PM
BowtieConvert
Mario
Sent you a PM.
  #489
Old 02-28-2019, 04:31 PM
bansheemike's Avatar
bansheemike
bansheemike is offline
Installed a MBRP 5 inch filter back exhaust with 6 inch tip.
  #490
Old 03-04-2019, 05:28 AM
rewillia's Avatar
rewillia
rewillia is offline
Originally Posted by Larrymac52
CQuartz UK ceramic coat
Looks great. I'm scheduled for both clear bra and ceramic applications this week (silver spruce),
  #491
Old 03-04-2019, 09:17 AM
Maiden666's Avatar
Maiden666
Maiden666 is offline
Airbus driver
Originally Posted by bigred460ci
F350 6.7 SCLB
Stableload #A7311S.
Looks good! How long was the install?
  #492
Old 03-04-2019, 03:38 PM
jbrnigan's Avatar
jbrnigan
jbrnigan is online now
Budget....."Stableload".......Since I only use my F-250 for towing, my polyethelene spacers are pre-set for engagement with a few hundred lbs load. Have no effect on "unloaded" ride. (4 polyethelene wedges and 4 polyurerthane bump stops)
  #493
Old 03-05-2019, 01:31 PM
bigred460ci
Hard to say on the air bags, the weekend I installed them I had a couple other projects going on so I was back and forth on it. Torklift sent me the drill kit about a week before sending the stableloads, did the drilling and install on two different weekends. I took my time with drilling, probably took me about a hour, same with the stableloads, had to make a few adjustments with the amount of washers needed for the proper spacing. Had the truck on a lift which makes life a lot easier.
  #494
Old 03-24-2019, 09:46 PM
B3205's Avatar
B3205
B3205 is offline
4.5” Carli backcountry 37” toyo Mt 17” icon rebound HD
DB customs grille
  #495
Old 03-25-2019, 09:54 AM
Lvrkight6481's Avatar
Lvrkight6481
Lvrkight6481 is offline
Proz trifold cover
Quick Reply: What did you do to your Superduty today? 2018 version.
