What did you do to your Superduty today? 2018 version.
#436
#437
#438
#439
Builtright Industries
I have already installed the rear seat release mechanism ( https://www.builtrightind.com )
from these guys and went ahead with the rack mounts in the bed. These are great products and the customers service is really good. It was (is) a pleasure doing business with them. The install was easy and quick.
#444
#445
It’s the pre-runner from Trailready. Very nice work. I got it bare and had it powder coated locally as close to the vehicle color as I could get.
The fogs are original stock and the driving lights are PIAA 6”. The winch is the 16.5Ti from Warn.
#446
How much was the powder-coating? About to order a Fusion with full grill guard or the Fab Fours with the same..LineX quoted me about $450 to put on the LineX...I think it might wear a bit better than the powdercoat...
#447
#449
#450
Finally rounded out my lift and put on a Fox ATS Stabilizer. 15 minute install. You do need a buddy or wife to help you out. The steering wheel has to be held at full max to the right to mount the clamp (with 1/8" of shaft showing at that point). Set it to "12" of 24 settings to start. Didn't go on a drive, just backed it back up into the driveway - it did make the steering feel a little more sturdy than it was. So I will play with adjustments. I also did have to rotate the reservoir to avoid it from hitting anything. Easy adjustment - just an allen bolt on the L bracket clamp to rotate it.
