Heavy steering sometimes when stopped
Diesel engines don't generate any significant reliable vacuum, so nothing there to operate a typical brake booster. (Gas engines with "big" / "lumpy" cams with lots of valve overlap can have this problem as well.)
Instead, diesels will piggyback off the power steering system, to provide power to a hydraulic brake booster instead. Normally, if the system and all its components are well matched, this works fine.
Except, that is not the case on the SuperDuty
The hydroboost power steering system that we have is integrated with the power brake system. Even the folks who understand this, still don't understand that applying the service brakes will effect steering effort, without anything being "wrong" or restricted or out of order. It is the design... but it is not a limitation.......
A number of people have done a Saginaw pump conversion, which replaces the power steering pump with a higher flowing, quieter, longer lasting GM Saginaw style pump. The problem is a bolt-in minimal hassle kit is expensive. Due to some issues with pump body clearance ( on the mounting bracket) and especially with pulley alignment, piecing together a DIY home built setup is challenging.
I intend to do some more research on this, and go this route when I do my major truck overhaul in the summer. I just hope my failing stock pump doesn't lock up before then. At this point, it feels like its barely moving any fluid at all. I hate the idea of having to waste money on a "stock" style replacement now, only to throw it out later.
I am surprised (if) they are in series and asked if it uses a power beyond, using hydraulic systems lingo.
Small google-hit discussion that describes it, compared to priority valve.
It sounds like a priority valve setup for brakes, or direct series. Which one, I don't know.
I do get irritated sometimes- recently even- but not very often and not for small things.
Besides, he's often helpful and I don't mind a bit of ribbing- especially if I post something dumb or incomplete because I was rushing.
I hoped someone who was familiar with hydraulics would pick up on that right away and tell me which way it is.
Thanks
All my tires were running low. Aired them up and now the EX runs as intended. Thanks for the reminder to look for basic stuff first
