driveline help
Old Jan 5, 2018 | 03:26 PM
Reddman's Avatar
Reddman
driveline help
OK, I'll be perfectly honest, I have never owned a Ford with an automatic transmission. Can't find a diagram for the 2 piece driveline in my 1978 f-350 flatbed dump with the long wheel base. I know when you pull the yoke out of a GM product the tranny fluid comes with it. any help?
Old Jan 5, 2018 | 04:03 PM
Locoforfomoco's Avatar
Locoforfomoco
Your Ford is the same. What you probably have is a u-joint flange that is attached by a nut or flange to the end of the trans main shaft. This shaft will go to a carrier bearing attached to the frame with a u joint on the rear with a slip yoke on it. Yours will be the bottom pic.
Old Jan 5, 2018 | 07:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Can't find a diagram for the 2 piece driveline in my 1978 F350 flatbed dump with the long wheel base.
Ask and ye shall receive:
Old Jan 8, 2018 | 08:32 AM
Reddman's Avatar
Reddman
Thanks Guy's,
Pulled the drive shaft this weekend, pretty sure this has never been done to this truck. Had to cut the bolts off that hold the carrier bearing & the clips on the U joint caps came out in pieces & couldn't press out the joints with a 12" vise. Time for some heat & a hydraulic press.
Old Jan 8, 2018 | 02:58 PM
79F150400M's Avatar
79F150400M
Not sure which side of the mountains your on, but if you can get your driveline to Drivelines NW in Everett they can get you fixed up. Ive used them twice now and I highly recommend them. The can do balancing too which can save headaches down the road.
Old Jan 8, 2018 | 04:46 PM
Reddman's Avatar
Reddman
I am on the same side as you, but in the Longview area. There is a good shop in Vancouver if I get stuck.
Old Jan 9, 2018 | 05:41 AM
CharlieXLT's Avatar
CharlieXLT
Curious... does that center support bearing just slide off the shaft? Does it typically need a little influence of a rubber mallet? I will likely be replacing mine in the near future.
NumberDummy: Does that rubber insulator in the above diagram (part no. 4826) still exist?
Old Jan 9, 2018 | 08:24 AM
Reddman's Avatar
Reddman
I am not sure Charlie, hopefully I'll find out tonight if there is no honey do's. I'll let you know how it goes.
Old Jan 9, 2018 | 02:33 PM
79F150400M's Avatar
79F150400M
Very cool! I lived in Castle Rock as a youngster.
Old Jan 9, 2018 | 02:40 PM
NumberDummy
Comes with the driveshaft center support kit: D9TZ-4800-A (replaced D4TZ-4800-A and the individual parts used prior years) / Recently obsoleted, but available NOS & from auto parts stores.
Fits: 1965/90's F100/250 & some F350's.
Old Jan 9, 2018 | 04:24 PM
Reddman's Avatar
Reddman
That is cool. Grew up in Vancouver & have worked in Woodland most of my life & looking forward to retire this year. Then I will be in your area since we have property on Guemes Island.
Old Jan 15, 2018 | 09:56 AM
Reddman's Avatar
Reddman
It's done, but what a bi#@H. Had to use the 20 ton press at work to push everything apart & at one point didn't think that was going too work. Everything went back together fine after cleaning all the rust, dirt & grease. The bad; I still have a small vibration. Hopefully didn't harm the driveline from having to put so much pressure on it. Will inspect this evening if it's not pouring rain.
GeorgeL
Apr 25, 2019 11:20 AM
1970XL351W
Jan 6, 2014 11:17 AM
Bill Payne
Dec 23, 2013 01:55 PM
Steve Straus
May 19, 2008 06:41 PM
ford390gashog
Sep 18, 2005 07:46 AM
