2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Expedition won't shift
Old Jan 4, 2018 | 01:12 AM
Stacylynb's Avatar
Stacylynb
I have a 2007 Expodetion El 4x4 that is stuck in park?
Old Jan 4, 2018 | 05:58 PM
pdqford's Avatar
pdqford
Do your brake lights work?
If it is because of the shift interlock, check your owners manual. It may have an explanation of how to over ride the interlock to get it out of park
Old Jan 5, 2018 | 07:59 AM
alloro's Avatar
alloro
I've heard if you turn the key without starting, place your foot on the brake and then shift to neutral, it will shift out and you can start it in neutral.
Old Jan 5, 2018 | 10:12 AM
hank_2010's Avatar
hank_2010
you might need to replace the brake pedal position sensor, had one go out in a 2010 and it would do the same thing. check to see if the brake lights are coming on and if you hear a click from the center console when you press the brake pedal.
F350Man79
Oct 10, 2022 10:12 AM
2803JW
Nov 12, 2018 09:54 AM
busdriver47
Jun 25, 2009 03:09 PM
david49892
1983 - 2012 Ranger & B-Series
Apr 30, 2008 12:08 PM
true sir
General Automotive Discussion
Oct 25, 2007 08:22 PM
