the weather man
Old Jan 4, 2018 | 05:00 AM
granddaughters's Avatar
granddaughters
the weather man
I got a 72 F250 sport custom camper special. It's got a 360 and over 500,000 original miles. I recently blew a head gasket so I fixed it I got it all back together and now she won't start it's got a new coil new plugs points condenser plug wires are less than a year old, I got Spark it's getting fuel check double check triple check 5 times today my timing firing order and soon as I get this posted I'm going back out to check it again I don't know what else to do can anybody help me please
Old Jan 5, 2018 | 12:57 PM
Brian1971f100's Avatar
Brian1971f100
Dizzy 180 out ?
Old Jan 5, 2018 | 01:43 PM
Alex from GA's Avatar
Alex from GA
I'm kinda with Brian. Are you sure you're @ TDC? Either take the valve cover off on the passengers side, rotate the engine to TDC, make sure the valves on #1 are closed. If one is open you're 180* off, rotate the engine one revolution. The rotor should point to #1 on the cap. You will have to rotate the distributor some to get it to start. Or stick your finger over #1 spark plug hole and turn the engine until you feel compression. The next time TDC comes up it'll be in the right place.
granddaughters
Jan 8, 2018 05:06 AM
Doctomario777
1983 - 2012 Ranger & B-Series
Mar 12, 2013 07:59 AM
mountainman47
Aug 28, 2010 09:44 PM
davdmad
32
Nov 30, 2009 07:32 AM
pootscratch89
Jul 1, 2005 12:44 PM
