4x4 help
Old Jan 3, 2018 | 02:47 PM
7.3Excursion4x4's Avatar
7.3Excursion4x4
4x4 help
Haven’t used 4x4 in forever. Went out in the snow today and put into 4x4 low on the dash switch. Felt a small vibration. Pulled over didn’t see anything. Locked in the hubs. Got in and as soon as I hit the gas, huge vibration. Let off gas, no vibration. Back on the gas, huge vibration. Unlocked hubs and left in 4x4 low and slight vibration but didn’t feel like the 4x4 was working.
U-joints near hubs look fine.
There is not any vibration when in 2wd.
Thanks in advance
Old Jan 3, 2018 | 02:54 PM
Oldguyfl's Avatar
Oldguyfl
My guess one of the u joints or all of them are not happy in either the front driveshaft or axle drive shafts.
When you unlocked the hubs you had less vibration, but still had some. That points to front DS, when you locked em up you had more, that points to axle shafts. 2wd you had none.
This is probably why they are out "Haven’t used 4x4 in forever."
Bet it crunches real bad in the front when making turns with 4x4 engaged too. U joints
Old Jan 3, 2018 | 03:01 PM
7.3Excursion4x4
I guess that’s probably true. I only use 4x4 when coming out of boat ramps or pulling people out of mud or ditches. Just haven’t used it to drive at speeds in a while. Unfortunately have a 900 mile trip I’m leaving for tomorrow evening up to the mountains of WV. Gotta figure this out quick
Old Jan 3, 2018 | 04:25 PM
seville009's Avatar
seville009
4lo will only engage when you’re stopped with the brake pedal pressed and in neutral.
Same to disengage 4lo
Old Jan 3, 2018 | 04:39 PM
7.3Excursion4x4
Not clunky when turning. I’m aware that 4lo only comes on when stopped in neutral with foot on brake.
I got it to my friends shop and have it on jacks now lookin at it. Don’t see anything initially. U-joints seem ok.
Gonna disconnect rear drive shaft and get the fronts spinning to see if I can see the problem
Old Jan 3, 2018 | 04:41 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I posted extensive 4x4 info, and it is in the tech folder now. Mostly applies to 00 & 01.
Old Jan 3, 2018 | 04:44 PM
Oldguyfl's Avatar
Oldguyfl
Interested, let us know.
Superduty ROCKS
Feb 27, 2014 02:38 PM
1987_XLT_Lariat_F250
Jan 6, 2014 10:55 AM
Skinner F350
Sep 12, 2012 08:32 PM
Dan Taylor
Mar 4, 2010 05:02 PM
Pete in Maine
Jan 30, 2008 06:20 AM
