Before I buy a new compressor
Old Jan 3, 2018 | 01:15 PM
03silvernavi's Avatar
03silvernavi
I just want to be sure that mine is bad. The navigator is an 03 and I tested the connection going to the compressor with a volt meter. I am getting 13 volts up to the connector leading to the compressor and no voltage on any of the wires on the wires after the connector going to the compressor. Does this confirm that the compressor is done?
Old Jan 4, 2018 | 07:52 AM
carid's Avatar
carid
Former Vendor
If you have tested the compressor directly with the test wiring and fuse between - yes, it's dead. There is still a small possibility that there is a sort of electric problem in the chain if you haven't measured the power directly at the compressor connector. And here's an estimate for the aftermarket air compressors for an 03 Navigator - just for you to consider. https://www.carid.com/2003-lincoln-n...ir+Compressors
Old Jan 4, 2018 | 08:28 AM
2trux's Avatar
2trux
If you have voltage on one side of the connector but not on the other it sounds like a bad connection in the connector. I would disconnect the plug and put power directly to the compressor.
Old Jan 4, 2018 | 09:30 AM
alloro's Avatar
alloro
With the connector still plugged into the compressor you should have 12v or more at the connector when the system is on. If you do it's a bad clutch coil, if you do not there is a problem elsewhere. If you're knowledgeable and have an average set of tools, it is possible to change just the coil instead of the whole compressor.
Old Jan 4, 2018 | 10:22 AM
03silvernavi
But shouldnt the voltage travel all the way to the compressor even if it is bad instead of stopping at the connector?
Old Jan 4, 2018 | 04:03 PM
03silvernavi
i spliced the wire after the connector and put 12 volts to it. All i get is a clicking noise
Old Jan 4, 2018 | 05:51 PM
pdqford's Avatar
pdqford
Just for my own understanding, are you talking about the AIR compressor or the A/C compressor?
Old Jan 4, 2018 | 05:53 PM
03silvernavi
air suspension compressor
Old Jan 5, 2018 | 07:48 AM
alloro's Avatar
alloro
You should've mentioned that.
Old Jan 5, 2018 | 01:16 PM
03silvernavi
and you shouldn't have assumed that. What is more prone to failure on these vehicles? An air suspension compressor or the a/c compressor. Thanks for your input
Old Jan 5, 2018 | 04:49 PM
pdqford's Avatar
pdqford
Neither. The air suspension compressor fault is usually the MOSFET relay. (Bring money. )
Old Jan 5, 2018 | 06:30 PM
03silvernavi
Got a new air suspension compressor today and its doing the same thing .. 12+ volts coming out of the connector and only 0.05 volts from the connector to the compressor.
Old Jan 5, 2018 | 06:32 PM
03silvernavi
where exactly is the relay located on my 2003?
Old Jan 6, 2018 | 08:38 AM
alloro's Avatar
alloro
I'm not the one asking for help you are, that makes it your responsibility to be clear as to what you're looking for. People are here to try and help, none of us here like to waste our time playing guessing games.
Old Jan 6, 2018 | 08:40 AM
alloro's Avatar
alloro
Under and behind the passenger headlight assembly.
