2018 Superduty - Lane Keeping system is worthless
So I have the lane keeping system on a 150 and a Fusion and the Lane Keeping System in both of these vehicles can be configured to "Assist" or nudge you with slight steering pressure back into your lane should you drift. It actually works quite well.
Enter the Superduty.
I learned the hard way that Ford in all of its wisdom sells a disabled version of this on the Superduty's that only has the option to send a slight vibration through the steering wheel to alert you should you drift, it will not give you the "nudge" that might get your attention. It is apparent that the engineers behind this system may have never driven a Superduty, and do not realize that this is a heavy duty truck which does not ride like a Cadillac, so if the road you drive is not paved like a mirror you will not notice if the vibration is from the road or the system. I live in Florida so we don't even have the potholes like the northern folks, but our roads are always under construction and this system is not worth .02 in the SD.
P.S. - GMC / Chevy will at least make the seat vibrate which is far better than making a already shaking steering wheel shake.....
What is the adaptive steering? Is it not electric assist?
Sam
As for the feature, Ive turned that, and the crash avoidance off (beeping, and red light reflected in the windshield).
The way I understand it on my 17 Platinum is the adaptive steering continually adjusts the ratio between the steering wheel input and the rotation of the front wheels using an electric motor with computer input and a gear unit to amplify the steering wheel’s rotation based on wheel angle.
It is suppose to help reduce the steering effort by tightening up the steering ratio depending upon speed (only works at slow speed) and steering angle, Ford states it can reduce up to one steering wheel rotation.
Not sure I have noticed it yet but I have not towed anything with my truck.
As we move into more and more active assist features and automation in our vehicles, it is REALLY important to understand how the language surrounding these systems work. Keep in mind, every clown in a marketing department wants you to think that you're getting the best product possible, when in fact you're just getting what engineering can do with the money they're allowed to use.
Here's the basics of how not to get hoodwinked by the marketing department.
Passive systems: us the words 'alert' and 'warning'. These don't imply that the car is going to do anything other than LET YOU KNOW that you've done something a system is monitoring for. Aside from being more time sensitive, functionally it isn't really any different than the low fuel light.
Active systems: 'assist', 'aid', etc. These words clearly state that the vehicle is going to HELP YOU correct the issue that it has detected. Most often these systems are stacked on top of the passive systems' features using onboard hardware to help you stay in your lane or whatever the system in question monitors.
An example I can give of this is also on our Super Duty - adaptive cruise control. The actual language that Ford uses is "adaptive cruise control and collision warning with brake support." Note the way they present it as brake support (active system) stacked on top of the collision warning (passive system). Thankfully in this situation they put 'brake support' in the name, but as we see so often it just isn't very clear.
All that said, I'll return to Ford sucks at language. Somebody in marketing ought to get smacked for not better clarifying between Lane Keep Assist and Lane Keep Alert. In my world, nobody has a passive system and an active system that could have the same acronym.
Sorry you didn't get the option you thought you were going to.
-bill
