Rear Upper Trailing Arm Removal
Old Jan 2, 2018 | 12:07 PM
kythri's Avatar
kythri
So, the air suspension on my 2000 Expedition EB crapped out (compressor, I believe), and rather than try to fix that, I've purchased a conventional replacement from Strutmasters.
While I'm tearing into this, I figured I'd replace all of the other suspension components.
I've got the air springs and shocks removed from the back, and started working on removing the rear trailing arms, beginning with the uppers.
After beating on it with an impact wrench forever, I finally got the arm-to-axle bolt/nut out on the passenger side, breaking the nut weld to the retainer bracket. After beating on the driver side, then taking a break and examining the bolt on the passenger side, it appears there's blue Loctite around the bolt threads.
On the driver side, I've succeeded in breaking the nut weld again, and simply cannot break the bolt free from the nut.
Anyone got a trick to this? Am I going to have the same issue on the arm-to-frame bolts, or on the lowers? This doesn't feel like it should be this tough to bust some bolts out.
Old Jan 2, 2018 | 12:48 PM
alloro's Avatar
alloro
You need a stronger impact wrench, or if using extensions or swivels try to not. Your next option is a breaker bar, which believe it or not can apply more torque than an air gun. Last option is if you have torches, heat the nut red hot then try breaking it free.
Old Jan 5, 2018 | 08:07 PM
kythri's Avatar
kythri
Looks like breaker bar was the answer.
Should have tried that before the impact gun, or shortly after the impact failed to budge.
Thank you for the advice, apologies for being an idiot and not thinking of that first.
johnoconna
Modular V8 (4.6L, 5.4L)
Nov 10, 2016 02:49 PM
FordBoy2012
1997 - 2003 F150
Apr 14, 2013 07:07 PM
Timothyap5vm
Aerostar
Jan 26, 2010 08:14 AM
BADAS03SVT
Jun 29, 2008 09:18 PM
speedr26
1997 - 2003 F150
Jan 31, 2007 10:08 PM
