2016 XLT Charging System Voltage
Old Jan 6, 2018 | 11:01 PM
ford390gashog's Avatar
ford390gashog
Was the BMS reset using IDS? This will reset days in service and adjust the charging curve. Also the internal temp of the battery is calculated by the BMS and it will try to heat a cold battery by charging up to 16v. You need to watch the alternator on IDS or forscan and see what the amperage output is and watch the load shed. It sounds like the system needs a reset.
Old Jan 7, 2018 | 04:24 AM
shortride's Avatar
shortride
Originally Posted by storage_man
What are you stating ??? This thread is not about test equipment its about a battery problem the OP has in low temp conditions !!!
He is measuring 15 volts at the battery. He obviously did that with some sort of voltmeter. I was only stating that his test meter could be off by =/- 10%.
Bills68F250
Sep 28, 2016 11:04 AM
weyland426
6.4L Power Stroke Diesel
Mar 2, 2015 08:27 AM
AbandonedBronco
1978 - 1996 Big Bronco
May 8, 2012 12:35 PM
dancraig
Jan 23, 2012 10:00 PM
RhinoScores
1983 - 2012 Ranger & B-Series
Feb 8, 2010 09:12 PM
