Cargo box/bed power outlet HELP
Have a 17 F250. I have looked and looked and cannot find a part number or a name for the part. I think it is part of the 5th wheel package. I’m looking for the plug that goes in the rear left side of the bed. I want to plug in a small Engel fridge into it. Any help would be greatly appreciated. Thanks
If you are looking for the Bargeman plug for fifth wheel, here is what I installed:
https://www.etrailer.com/Wiring/Barg...7-410-010.html
Super easy, clean install. Not sure it's what you want though, and you may have issues getting power to your fridge. I understand the 12vdc charging circuit isn't energized until you step on the brake, or something like that. Anyway, it may bear further investigation before investing.
Yes, kinda like that but I was hoping for the Ford OEM version. I talked to a guy in a parking lot that had the plug from the factory, said it came with fifth wheel tow package..he also said you need to trick the plug into thinking a trailer is plugged in for it to get power.. he had an adapter plugged in and THEN the fridge was plugged into that.
Is this what you are looking for? https://accessories.ford.com/exterio...ics-11629.html
SD Dually
Mar 7, 2014 05:08 AM
respolt
Jul 14, 2011 06:21 AM
CA-F250
6.7L Power Stroke Diesel
Jun 19, 2011 09:37 PM
