Sponsored by: Real Truck
4r100 trans shift points
Old Jan 1, 2018 | 08:01 PM
MTP55's Avatar
MTP55
I was out on the expressway today and got to the seed limit. Which was 75, and the tach in the truck was reading out around 2500. It felt like it wanted to shift soon but never did. I know a year after it was bought the dealer did a PCM reprogram. Would this be normal under any circumstance or do I have an issue? The truck is an '00 F-250. 7.3
Old Jan 1, 2018 | 09:56 PM
Lawnpro979's Avatar
Lawnpro979
Does sound a little high
Old Jan 1, 2018 | 10:13 PM
MTP55's Avatar
MTP55
That's what I thought.
Old Jan 2, 2018 | 11:04 AM
bwguardian's Avatar
bwguardian
Sounds more like a torque converter, but does it change if you hit the OD button?
Old Jan 2, 2018 | 11:08 AM
MTP55's Avatar
MTP55
Not sure. Normally only on the expressway twice a year and that's only for about four exits. Haha. Never had any issues anywhere else.
Old Jan 3, 2018 | 11:55 AM
brian42's Avatar
brian42
Veteran: Navy
Sounds like you never shifted into OD. TC locks up around 45-ish mph IIRC. Feels like a 5 speed as the shifts are 1 - 2 - 3 - TC lockup - 4(OD).
There's a former Ford transmission engineer on here that knows these things inside and out....@Mark Kovalsky. He could give you some insight.
Old Jan 3, 2018 | 12:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I was waiting to see if the OP answered what happened when he pressed the OD OFF button while at 75 MPH. Right now there isn't enough information to make any call.
Old Jan 3, 2018 | 05:41 PM
MTP55's Avatar
MTP55
No, I have not pressed the button. I may get a chance to get back on the expressway this Saturday so I can try it then. I remember the shift after 45. It was normal.
Old Mar 2, 2018 | 06:42 AM
MTP55's Avatar
MTP55
Just a thought here, haven't been back on a go fast road yet, will be next weekend though. My third brake light doesn't work. I've heard people say things about that screwing up thing with the TC. Could that be part of my issue maybe?
Old Mar 2, 2018 | 10:07 AM
Mark Kovalsky
Yes, it could be the problem.
Old Mar 2, 2018 | 10:22 AM
projectSHO89's Avatar
projectSHO89
On a 2000, it shouldn't matter if the CHMSL works or not. The PCM sees the BPP signal from the other half of the switch, not the half that runs the CHMSL and the regular brake lamps which are in parallel. Later models that require the bulb filament to "pull down" the otherwise open-circuit voltage at the PCM to a logical low state would be affected. That's also why later model speed controls don't work if the bulb is burned out or LEDs are swapped into the CHMSL.
In any event, if your CHMSL doesn't work, fix it. The vehicles behind you will appreciate it.
Old Mar 2, 2018 | 08:49 PM
MTP55's Avatar
MTP55
I didn't know it didn't work until my buddy finally decided to tell me the other day. Would have been good to know awhile ago. The brake lights on the box work fine.
Old Mar 6, 2018 | 06:16 AM
MTP55's Avatar
MTP55
Would splicing this socket in for the third brake light work? It looks the same. None of the parts stores carry the harness or socket and Ford wants $50.
Old Mar 12, 2018 | 07:55 AM
MTP55's Avatar
MTP55
Yesterday I was on the expressway, going to Roscommon, and there weren't any other people around so I hit the OD button at about 75 the truck immediately sent the rpms to 3000 maybe give a hundred. So I pushed it again and it dropped back to 2000 which is about where it ran the entire drive.
Old Mar 12, 2018 | 08:25 AM
Mark Kovalsky
That proved that the trans was in overdrive. 2000 RPM at 75MPH is correct, which tells me that overdrive works and that the torque converter is locked. Everything is as it is supposed to be.
