04 Parchment Door Panel Color
I see it's a somewhat common problem for those that are left out in the sun, the tops of my drivers and passenger door panels have faded. For my 04 EX, which version of Parchment is correct?
Thanks, and Happy New Year!
I found other threads that talk about dash color, but not the lower dash and door panel color of the EX.
Thanks. I'm also getting a triple gauge holder that I'm going to invert and trim/modify to fit that concaved area below the little pocket on the center lower dash. I need a mount location for my MaxTow Transmission Temperature Gauge, Trailer brake control, and my XM/Sirius XpressRCi radio. Will need to paint the pod as it comes in black.
He put the SEM in the pictures so when I did a search for "SEM 17033" and "SEM 17053" that post did not show up. I picked up a can of "Desert Sand" that I found at my local auto parts store and tested a spot thinking I could blend it in, but it has too much of a golden look.
If you are referring to me, here is the link where you can buy it.
https://www.amazon.com/SEM-17053-Med.../dp/B000H6O2W4
When you have a chance, I'd appreciate it. My searches for "Medium Dark Parchment" keep showing up as "SEM 17053 Medium Parchment". I guess I could use what I already have and it would not really look out of place.
