Glow Plug Relay/ PCM
Old Dec 31, 2017 | 05:22 PM
akmikek's Avatar
akmikek
I just installed a new GPR on a 2000 F450 and when i turn on ignotion i am still not getting power to the large post that goes to the glow plugs? I also get P0380 glow plug system code. When i hook up meter to the negative battery post and small terminals on the GPR, i get 10.5v-11.5v on bothe of the small posts with key on engine off. I get 12.4v on large post with key off and nothing on small posts with key off. I dont see a glow plug module on the valve cover. Any idea why i wouldnt get power to other large post with key on if im getting current to both small posts? Is the small post furthest from the firewall supposed to have power with key on? What else can i do to troubleshoot the glow plug system?
Old Dec 31, 2017 | 05:27 PM
Walleye Hunter's Avatar
Walleye Hunter
You shouldn't have current to both small lugs. The one towards the firewall leads to the PCM and gets grounded when the PCM calls for glow plugs to be activated. Power to the one large lug at all times is good, power to the front small lug key on is good. The engine oil has to be cold (I forget what the temp threshold is) for glow plugs to be called for. Is your engine cold enough?
Old Dec 31, 2017 | 06:22 PM
johnsps250's Avatar
johnsps250
I believe you should be getting 12v if you read from either small post to ground with the key on. The PCM doesn't appear to be providing a ground to close the relay.
Old Dec 31, 2017 | 09:46 PM
akmikek's Avatar
akmikek
Could this be a bad ground going to the PCM? Where is the ground for the PCM?
Old Jan 1, 2018 | 06:27 AM
timmyboy76's Avatar
timmyboy76
Mine did the same c thing. After 2-relays I thought v were bad, it was evident, something want right. Conclusion for me, was to run a write from the ground side of relay, to a switch, then to ground. Have to manually operate the system... Beats a new pcm.... Use the gpr-led mod so you know that the gor's are wiring and that you don't v leave the switch, on.
tjc transport's Avatar
tjc transport
i ain't rite
over 110 degrees engine temp the glow plugs do not work.
Old Jan 1, 2018 | 11:07 AM
johnsps250's Avatar
johnsps250
I agree with the above, I am not sure exactly what parameters can disable the GPR, I'm sure someone will chime in with that info shortly. But I would check those parameters before condemning the PCM and using a work around. Could be as simple as a bad temp sensor.
If all else fails, a switch in the cab to manually provide a ground will work also.
Old Jan 1, 2018 | 01:30 PM
tjc transport
i ain't rite
also make sure they did in fact gave you a glow plug relay and not a starter relay. parts store counter monkeys are dumber than a box of rocks, and do not know the difference.
Old Jan 1, 2018 | 02:06 PM
Hussler's Avatar
Hussler
There is not a actual ground wire going to the PCM, physically. One of the small terminals on the GPR goes to the PCM internal electronics and it grounds the wire to activate the GPR.
First you need to troubleshoot with the engine cold. And then you probably only have 45 seconds or so to measure voltages before the PCM deactivates the GPR. Gota be quick! You can recycle the key and do it again as long as necessary, just don't start the engine and get it warm-hot. I see you're in Oregon coast so it's not too cold, compared to other regions this time of year.
You are not really getting current from both small posts. With key ON one small post will be at battery voltage at all times and the other will be the same, it's just a coil of wire until the PCM pulls that line to ground during the GPR cycle thing.
Old Jan 1, 2018 | 02:23 PM
akmikek's Avatar
akmikek
Thanks for all of the responses. It looks like i will do the switch/LED mod? Does anyone know of a DIY or diagram for this mod? I couldnt find anything online? I would assume that i remove the PCM lug off the small post nearest to the firewall and run a wire from a good chassis ground through a switch to the small post the PCM lug was on? Could i just leave the PCM wire on and add a wire for a switch? If i use a switch with an LED will it shut off automatically once the relay shuts off? What about a push button switch so there is no risk of accidentally leaving it on?
Old Jan 1, 2018 | 03:30 PM
tjc transport
i ain't rite
as long as the relay is grounded, the glow plugs will be powered.
Old Jan 1, 2018 | 04:33 PM
akmikek's Avatar
akmikek
Great. Thank You
Old Jan 1, 2018 | 04:42 PM
Walleye Hunter
You could use a push button or should be able to find a momentary rocker or toggle switch as well if you wanted.
Old Jan 1, 2018 | 05:45 PM
MiamiPSD's Avatar
MiamiPSD
Google....wood n things or wmriceman. I believe he has a few write ups on the LED mod and how to check your GPR.
obscalvin
Apr 9, 2019 08:32 AM
Jo7.3
25
Jan 12, 2018 09:40 PM
68Mercury250Ranger
Oct 20, 2016 09:21 AM
jel15225
Feb 14, 2014 05:13 PM
chonka
Nov 18, 2004 03:09 PM
