engine troubles
I am at a total loss as to what it is but im getting frustrated that ive thrown all my money at it and am still left with a truck that dosnt run. people tell me to sell it but my grandfather is my hero and i plan to give it to my grandson when im old. being only 17 i have little money to throw at it. i have a job so i have a little but nothing extreme. so ill list everything i can about the motor.
FE 360
600 cfm
standart cam (it is hydraulic however)
new plugs and wires
newish starter
when rebuilt they put better valves and springs in but that wasnt me
new alternator
thats all i can think of off hand ask about anything and ill let you know what i know.
since im a kid i dont know everything even though i think i do, but im pretty good a researching and learning so im hoping you guys might be able to enlighten me.
please and thankyou for any ideas as to what it might be.
1. The rough starts on mornings below 40 degrees could be something to do with your choke. If you have an automatic choke and it isn't working (wide open during a cold morning) you may want to consider running a cable to it and manually adjusting it on cold mornings, until the motor warms up.
2. The backfiring while driving sounds like the timing is off. My first truck was also a 73 and mine backfired on the way home after getting my new dual exhaust installed. Sounded like a battleship had shot it's cannons through my window. Get someone with a timing gun and some know-how to make sure your timing is set correctly.
3. The weak startup could be your starter getting ready to go. Sometimes before they completely go, they will begin to peter out. That would explain why your battery checked out okay.
Like I said, I'm not a professional mechanic, but that's just a few suggestions. Good luck.
Know what I mean? When people don't have money to shower on their ride, sometimes they get to be better mechanics. A lot better mechanics. Why? Because when they can't afford to just keep throwing parts at it, and instead they have to know what they are doing - to divide and isolate systems, and through a process of elimination, determine the cause of the trouble remaining. Just like the repair manual instructs! Some of this stuff is big $$ (and everything is big money when ya ain't got none) so let's make sure it's really the problem, instead of replacing it only to find - that wasn't it! So you have an advantage in that sense, or at least an opportunity.
Start from scratch, step by step, system by system, don't take anything for granted. Find out what's good first. From the beginning. Does it have oil in the crankcase, that kind of thing. You'd be surprised for example, at how often spark plug wires get mixed up, and also, how decent it will still run that way. Check everything.
You can get a lot of manuals and repair books online, reprints are published of the classics. The various military branches had outstanding published courses, I'm sure these are public domain and available.
Point being you need to study this stuff first. A few tools and test equipment will go a long ways. Either rent or borrow. Compression gauge. Vacuum gauge. Tach. Test light. Voltmeter/DVOM etc. Welcome to FTE btw
Tedster9's post sums it up nicely.
If you can treat your truck like a project, and fix things bit by bit, you will get a huge amount of satisfaction.
You took out a racing cam, which should have come with 'heavy duty' valve springs.
The 'standard cam' would require lighter springs. Did you change them ?
Did you change the lifters ? Did you run in the cam as per manufacturer suggestions ?
When you say ''we changed'' etc, who is 'we' ?
Get yourself a Haynes manual or equivalent, then structure your project.
First job might be to check all ignition components.
E.G. Did you check the ohms on all HT wires before fitting them ?
Did you check the firing order and ignition timings.
Second job might be to check all earthing. (Starter and engine etc needs good earthing !)
Third job maybe to check all fuelling.
Your project will take time, a lot of time, but well worth the effort.
