2002 Excursion Headlight Issue
Old Dec 30, 2017 | 04:01 PM
bearup's Avatar
bearup
I drive a 2002 7.3L Ford Excursion that I haul cars with around the country for my customers using a tilt deck trailer. Recently, I installed new headlights and bulbs, and at the same time, also installed a Brite Box as well. While testing everything, I noticed that when I put the headlights in bright mode, the passenger side headlight turns off (bright and dim), but when pulling the multi switch onto the "Flash to Pass" mode, both headlights turn on bright, along with the low beams. This indicates that the Brite Box is functioning properly. I then took the Brite Box out of the circuit, and plugged the headlights back in the stock configuration, and in bright mode, the passenger side still drops out, but both work again in the "Flash To Pass" mode. Any ideas what might be the problem?
Old Dec 31, 2017 | 10:00 AM
alloro's Avatar
alloro
Can we assume you checked the fuse for the passenger headlight?
Old Dec 31, 2017 | 11:06 AM
projectSHO89's Avatar
projectSHO89
Problem with MFS or its connectors.
If any of the fuses for the bulb circuits were open, FTP wouldn't work correctly (it does).
Old Jan 1, 2018 | 06:56 PM
bearup's Avatar
bearup
Thanks for your input, guys. I was thinking it is a problem with the multi function switch or related wiring as well. I'll have to dig in and check it out.
Old Jan 2, 2018 | 11:13 AM
bwguardian's Avatar
bwguardian
Our Ex does the same thing though it doesn't shut completely off, just really dim. I have to pop the hood and get in there behind the headlight and move the wires around until it comes back on to normal. It has been doing this for many years.
Old Jan 3, 2018 | 04:08 PM
Aaron_Jones's Avatar
Aaron_Jones
I had to dismantle the column and and tap on the muti function switch and every thing is back to normal. It has been a year now I think.
Old Jan 3, 2018 | 09:06 PM
bearup's Avatar
bearup
I just ordered a new and upgraded multi function switch from 1A Auto for $35.95 shipped. Hopefully that will take care of the issue.
https://www.1aauto.com/turn-signal-a...=844113&y=2002
maybelle'84
Jun 21, 2019 03:46 PM
Vinford
Oct 31, 2018 10:29 PM
84tealbeast
May 31, 2006 11:34 AM
JMKiser
Electrical Systems/Wiring
Jul 22, 2004 07:25 PM
JMKiser
Bronco II
Jul 22, 2004 01:10 PM
