HELP! 7.3 2002 f250 issues
Old Jan 25, 2018 | 10:58 AM
Colorado350's Avatar
Colorado350
How many miles?
Have you checked fuses? Particularly #30 IIRC
Do you have a Wait to Start Light (WTS) coming on?
Fuel pressure gauge? Pressure?
Do you hear the fuel pump running?
Old Jan 25, 2018 | 11:43 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to related forum for better coverage.
Old Jan 25, 2018 | 11:56 AM
M.A.X's Avatar
M.A.X
Originally Posted by Justin Hernandez
Hey guys i am here in Georgia with a 2002 automatic 4x4 7.3 f250 Diesel.
It got a little cold here and i started having starting issues. It start 30 seconds later idle rough poof some white smoke then shut off. Id wait a minute then it would crank a little longer then start and be fine for the day. Happened for about a week. Then all of a sudden one night after driving all day wouldnt start at all. Also Check engine/glow plug/abs/battery light/ check gage lights wont go off at all. I did some research and started with my glow plugs, went in took them out tested them with multimeter on ohms and all 8 were bad. showed OL on 20 replaced all 8 then put back together, got 2 brand new batteries and still wont start. The dash lights are still not going out. It cranks but never fires. Sounds like it cranks normal for 10 seconds then continues to crank but sounds a little different. I also replaced fuel filter and there is fuelin the housing. Anything helps! thanks
Change the CPS. If still no run. IPR is bad
Justin Hernandez
13
Jan 25, 2018 08:17 PM
Dnixon
26
Nov 6, 2015 09:40 AM
Meydawg51
16
Oct 12, 2015 09:01 PM
YZGUYONE25
17
Jan 24, 2009 11:57 PM
jhoagland
Jun 13, 2006 09:13 AM
