94.5 7.3 will not start
Old Oct 10, 2015 | 08:05 PM
Meydawg51's Avatar
Meydawg51
150k miles f250 7.3 1994.5
Im Stumped
It will crank but will not start
Glow plug relay and glow plugs are good
Oil level is fine on the dipstick
When cranking fuel will fill the fuel filter housing
Batteries are good
It does crank slow
We have not replaced the cps yet
Not sure what else I should check or be looking for.
Old Oct 10, 2015 | 08:21 PM
z31freakify's Avatar
z31freakify
The only right way to diagnose a problem is by hooking up a compatible scanner, that way your not throwing parts at it and in the process you are saving money
Old Oct 10, 2015 | 10:52 PM
Action4478's Avatar
Action4478
Are you getting smoke ?
Old Oct 11, 2015 | 01:21 AM
Meydawg51's Avatar
Meydawg51
Sometimes it will puff a little white while cranking which I know means it's getting fuel
Old Oct 11, 2015 | 01:27 AM
Meydawg51's Avatar
Meydawg51
And I do have a scanner that can read icp
Ipr
And stuff readings should I get while cranking?
Old Oct 11, 2015 | 07:42 AM
farmert's Avatar
farmert
You stated that it is cranking slow, and the batteries are good, so the next question, how old is the starter? These engines need to spin over pretty fast to start. Are the battery cables good, and the connections clean and tight? Both pos. and neg. on both ends?
Old Oct 11, 2015 | 12:08 PM
Meydawg51's Avatar
Meydawg51
Batteries and all connections are good and I know it's like 500rpm while cranking is needed for the intectors to open or somewhere around that number
Old Oct 11, 2015 | 12:15 PM
z31freakify
Icp should be @ 500psi while cranking
Old Oct 11, 2015 | 02:30 PM
Meydawg51's Avatar
Meydawg51
That must have been where I got the 500 from but I do know it's has to have a certain rpm while cranking for it to start.
Old Oct 11, 2015 | 06:27 PM
z31freakify
Rpm should be above 200rpm I believe while crancking. Have you tryed to unplug the icp to see if it starts?
Old Oct 11, 2015 | 07:14 PM
Action4478's Avatar
Action4478
IPR DC % & ICP pressure is more important than RPM . Battery voltage above 10.5
Old Oct 12, 2015 | 04:10 PM
Meydawg51's Avatar
Meydawg51
Have bot tried that yet the icp is the one behind the hpop reservoir or near the hpop it's self?
Old Oct 12, 2015 | 04:11 PM
Meydawg51's Avatar
Meydawg51
What should the ipr and duty cycle be at while cranking
Old Oct 12, 2015 | 04:14 PM
madpogue's Avatar
madpogue
ICP is on the driver's side cylinder head, up near the front.
Old Oct 12, 2015 | 08:34 PM
Meydawg51's Avatar
Meydawg51
On the oil galley/rail?
