1994 4R70W problems
Old Dec 30, 2017 | 08:17 AM
AZmoparguru's Avatar
AZmoparguru
1994 4R70W problems
Hey everybody, I’m having an issue with the 4R70W in my 94 F150. The issue is, when the trans is at operating temperature, I’m getting a bad shudder during the 1-2 shift, similar to a converter shudder. The trans itself was rebuilt by Ford and only has about 30,000 miles on it. No issues with any other gear, there are no codes, and no issues with converter lockup. There is no material in the pan, always filled with Mercon V. I even installed a new bonded 1-2 accumulator, and swapped the shift solenoids and lockup solenoid and the result was no change. It will not act up at all when it’s cold. I’m about ready to pull it out and go through it and rebuild it, but was wondering if there was anything else I can check. I though about the EPC solenoid, but again, there are no codes. I’d appreciate ANY suggestions
Old Dec 30, 2017 | 10:06 AM
skuzzybucket's Avatar
skuzzybucket
Mine was TPS. It wasn't showing a code, Took it to Ford, they found it with thier scanner.
Replaced the TPS, good as new
Old Dec 30, 2017 | 10:19 AM
AZmoparguru
So yours was shuddering only when shifting into 2nd gear when warmed up? I put a DVOM on my TPS and didn’t see any dead spots, hot or cold. I would think if it was the TPS, wouldn’t it do it in every gear? The hotter it gets, the less throttle input it takes to make it shudder. Sometimes it won’t do it if you’re going around a turn, oddly enough
Old Dec 30, 2017 | 11:29 AM
skuzzybucket
Mine never got a chance to act up too much, as it was still under warranty
They did not cover the TPS, only told me that is what it was
I changed it out because my warranty was getting close to the end, and didn't want to argue later with them. Once changed, the problem went away
It only acted up for about a week. 2nd gear only.
Old Dec 30, 2017 | 01:04 PM
AZmoparguru
Interesting! The one on the truck is an aftermarket. I’ll have to look into that
Old Dec 31, 2017 | 01:36 PM
AZmoparguru
Well that wasn’t it. I replaced the TPS with a new Motorcraft part, and the problem remains. There is a what I believe to be excessive play at the output shaft/yoke, but no seal leak. I wouldn’t think that would be a source of a 1-2 shift shudder, only when hot
Old Jan 6, 2018 | 03:04 PM
AZmoparguru
UPDATE
UPDATE; picked up a kit and pulled the trans apart. The center support bearing that had gone bad about 6 months ago, ended up wiping out the output shaft bushing, which caused the failure of the intermediate clutch due to lateral play of the output shaft. It’s all put back together and back in the truck. I also added some P71 accumulator springs, and it shifts like a brand new truck
shawnvhs2003
1997 - 2003 F150
Jul 1, 2025 05:25 PM
AZmoparguru
Dec 31, 2017 11:41 PM
blue oval fan
6.7L Power Stroke Diesel
29
Apr 16, 2012 06:23 AM
My Good 'ol 92
30
Apr 11, 2012 10:36 PM
jethro
Jul 4, 2001 11:14 AM
