Bronco II Ford Bronco II
Lifting & Larger Tires
Old Dec 29, 2017 | 01:46 PM
Jmartens's Avatar
Jmartens
I think the B2 looks ugly if lifted too high. I also think it looks wimpy with stock wheel/tire sizes. I've heard that a 4" lift will allow for 33's. What about a 2" lift, does that help at all or not enough to meaningfully add larger tires?
What are your thoughts on fitting larger wheels/tires? Whats the best way to do it without rub?
Old Dec 30, 2017 | 01:36 PM
chrlsful's Avatar
chrlsful
The 1st Q to ask in any automotive Q is: "What's the application" end goal, daily or consistent use of the vehicle... off rd? mall craw? track? etc. An auto is a system & change to 1 prt effects all others.
there R differing opinions, mine:
I'd add a sm suspension lift (springs not blocks) & even smaller BL. Then use whatever sz tire fit safely (& could still carry 500#.)
The body lift seems to put too much weight up high & make tippier than a SL.
If ur just lookin to "profile" ur rig (lift for lrger tires for onlookers' entertainment) ranger station is a good spot for pic of different lifts and answ 2 tech Qs on lifts.
ufvj217
2009 - 2014 F150
Nov 2, 2015 10:07 PM
Gage2502
Jul 25, 2007 07:20 PM
qaswq
Bronco II
May 31, 2006 08:38 AM
emag
Feb 18, 2005 08:08 AM
13MWZ
Nov 14, 2002 06:44 AM
