Engine paint
Old Dec 29, 2017 | 12:49 PM
DocMSavage's Avatar
DocMSavage
Engine paint
I've been a big fan of the Velocity channel and many of the shows. Many of the high end builds like Kindigit and Chip Foose paint their engines beautifully and in a few shows the have older builds come in and the engines still look great! What do they use for paint?
Thanks guys!
Doc
Old Dec 29, 2017 | 02:13 PM
56panelford's Avatar
56panelford
Pretty sure it's the same paint they use on the vehicle itself. The engine block doesn't likely get as hot as the hood or roof would get sitting in the sun. Exhaust manifolds are a different story. I sprayed my case iron exhaust manifolds with VHT high heat manifold paint and have had no burn off, also sprayed my exhaust pipes as well..
Old Dec 29, 2017 | 02:52 PM
EBEAR's Avatar
EBEAR
Automotive paint should have no problem surviving on an engine " when properly applied " possibly with the exception of right at the exhaust manifolds on cast heads . As John said the roof or hood sitting in the sun can be amazingly hot .
Old Dec 29, 2017 | 03:25 PM
DocMSavage's Avatar
DocMSavage
It looked like it was just automotive paint...I'll just super prep everything before I shoot, its awhile off anyway. THe VHT stuff I put on the brand new exhaust manifold on my '79 F100 did not hold up too well.
Has anyone used any of that wipe on or rub in manifold dressing?
Doc
Old Dec 29, 2017 | 06:37 PM
firstrider's Avatar
firstrider
Put on very thin coats just to show color .
Old Dec 30, 2017 | 06:29 AM
Marauder2004's Avatar
Marauder2004
Last year when I rebuilt the engine in my old Mercury, I had my local automotive paint shop mix up a quart of standard acrylic enamel in Ford blue. I mixed per directions with a catalyst and after a year and approximately 1000 miles it still glistens. It has only darkened slightly where the exhaust manifolds attach.
capelo
30
Apr 6, 2013 07:34 PM
slojet
Feb 23, 2011 12:03 PM
John Morton
Nov 14, 2008 12:37 PM
MO-55F350
Aug 7, 2008 02:38 PM
crawlfish
Exhaust Systems
Mar 22, 2006 04:36 AM
