Engine Manifold Paint
Old Aug 6, 2008 | 12:34 PM
MO-55F350's Avatar
MO-55F350
Hello. I'm restoring a 1955 F350 with a 223ci I6 engine. I have already painted the block and head yellow with POR-15 engine paint. I have read a lot of conflicting information on the type and color of paint for the intake and exhaust manifolds (Black, Silver, Aluminum). Anyone know what the correct color was for that engine? Also, will regular POR-15 engine paint work or should I get their paint that tolerates 1000 degrees F?
Old Aug 6, 2008 | 02:38 PM
GreatNorthWoods's Avatar
GreatNorthWoods
I haven't tried the engine paint but I know the regular POR-15 will not hold up because I did try that. My guess is that you need the 1000 degree paint.
Old Aug 6, 2008 | 02:50 PM
9teen56f100's Avatar
9teen56f100
They make high temp paint for one reason, to keep paint on hot parts. I would use the high temp paint. You could have the exhaust manifold "jet coated". Mine has 40,000 miles on them and they still look great.
brian...
Old Aug 6, 2008 | 03:39 PM
fking1's Avatar
fking1
Intake manifold should also be yellow. The valve cover a light gray color. I used Eastwood cast iron manifold spray can for my exhaust manifolds and it has held up well.
Old Aug 6, 2008 | 04:50 PM
OldgreenF1's Avatar
OldgreenF1
I have the POR manifold paint on my flatheads headers. Its about 4 years old now and looks as good as when I put it on.
Old Aug 7, 2008 | 12:28 PM
MO-55F350's Avatar
MO-55F350
Thank you all for your thoughts. This helps.
Old Aug 7, 2008 | 02:38 PM
sandhillmike's Avatar
sandhillmike
The Eastwood manifold paint has worked well for me also
