noticed my front tires were making a loud noise, checked them and they were cupped. “ a new term to me”
learned it was because of worn shocks, replaced with Bilstiens, also replaced all tie rod ends, they were in bad shape.
Breaks, routers, have ball joints on the way. “ waiting for good weather”
my question is: will the cupped tires ever go back to smoothe?
Was thinking about moving them to the rear, the rear tires will need replacing in a few,
when the truck was purchased they would only purchase 2 tires at a time, so rotation was kind of not an option.
the cupped ones have about 60 to 70% tread left.
My truck came with one seriously cupped tire. Alignment off, original shocks and stabilizer, nearly 300,000 miles on the rig.
Speed increases cupping too. But I'm OK with blaming shocks, worn suspension parts, wheel balance, and alignment. I also know the PO drove this truck fast.
They will never get true again by rotating, but rotating often also reduces cupping. Worth noting if you do regularly drive fast.
Any big truck tire place will have a tire shaver as will most "race shops", if you replace the shocks and run cupped tires you will kill the new shocks in short time.
Cupped tires aren't always a result of worn front end parts. I owned one duty that always cupped the front tires. This happened with multiple different brand tires and multiple trips to the shop. I rotated the tires on that duty every 10,000km [6k miles] and that helped me get max life out of my rubber.
They will not warranty uneven tread wear. You can try, but it's gonna be "no dice". Sorry to say your only option is to replace the tires. I'd do all 4 as a set.
That being said, you need to sort out your truck first, before you put another new set of tires on them and trash those too. It won't take long to put an uneven wear on a brand new set of tires if your front end is hosed.
Take it to a GOOD front end shop, one that does a lot of trucks, and have them go through it. Steering components, shocks, bushings, even wheel bearings (if they get bad enough), all can contribute to uneven tire wear.
I drive a hyrail railroad vehicle that cups tires very quickly. I rotate tires often. It helps, but the cupping does not go away when they are rotated to the back wheels. Supposedly the extra front end weight of the hyrail gear contributes to the problem. I'm waiting until I get a new set of tires to get a good front end rebuild and see if that solves the issue. I have also had cupping on my personal rig, a dually that did not have the front wheels rotated because it had aluminum wheels. I have since gone back to steel wheels so that I can rotate tires as necessary. I have noticed that once the cupping first shows up it gets worse very quickly. I have been able to slow the process by vigilantly inspecting the tires and rotating them as soon as I notice cupping.
Yes. It kind of snuck up on me. The tires are about 1.5 yrs old. The next thing I knew they were getting very loud. Inspected them and WOW! This doesn’t make me look good, but I started inspecting, found shocks shot, tie rod ends. And ball joints. The truck was just getting wore out....I’m waiting on good weather to replace the ball joints, that’s the last thing on my list. Besides tires, and alignment....Owing a landscaping company, I dont really inspect as I should. But w live and learn.....
