Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Lower Decibel Air Compressor
Old Sep 13, 2003 | 01:12 PM
Skibo's Avatar
Skibo
Fein makes a Shop Vac with vast improvement in sound level from a typical Vac. You can easily carry on a conversation with it running right next to you. Has anyone found an air compressor with a lower noise level than the typical 89 db rating of a Sears Craftsman or similar?
Old Sep 13, 2003 | 03:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
The V-belt compressors as a rule are much quieter than the integrated oilless units. The biggest noise maker on a compressor is the air intake. Better filters are quieter.
Old Sep 13, 2003 | 11:44 PM
Skibo's Avatar
Skibo
Thanks for the reply...Would you happen to have a trade name or commercial contact for the V-belt compressor units?
Old Sep 14, 2003 | 12:15 AM
Torque1st's Avatar
Torque1st
Posting Legend
Almost every manufacturer or distributor has belt drive units. The oilless compressors are usually cheapo units where the motor and pump are all joined together as a unit.
This is a belt driven unit:
http://www.northerntool.com/webapp/w...tegoryId=90143
This is a oilless unit:
Old Sep 14, 2003 | 07:28 PM
eehoepp's Avatar
eehoepp
If the compressor is a stationary unit & you can plumb the air intake outside, you will cut down on the compressor noise considerably. Just make sure the piping is sized generously so you don't starve the compressor & if you use hose, make sure it's heavy enough wall so it doesn't suck flat in the vacuum.
If you really have too much time on your hands, you can crunch some numbers and build a small velocity stack for it. A buddy of mine did this. He didn't actually do any math, but he built an intake that both made the air compressor quieter and reduced it's recovery time. And it looked cool to have a small open-element air filter perched on top of the pipe.
Cheers,
Eric
Old Sep 14, 2003 | 07:50 PM
Mike W's Avatar
Mike W
I put mine behind the garage and built a lockable metal shelter for it.
Old Sep 14, 2003 | 07:59 PM
nickmobile67's Avatar
nickmobile67
I agree. I have two craftsman compressors, my year old one is the oilless kind and I can't stand the noise, my other 20 year old one is belt drive and is downright quiet compaired to the new one. I don't think the new one will last 20 years, but I think the old one will last 20 more.
And if not, you can replace individual components.
Old Sep 14, 2003 | 08:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
Watch out for annoying the neighbors if you live in an urban environment and you put a compressor outside...
Old Sep 14, 2003 | 08:52 PM
Duderoy's Avatar
Duderoy
I took a used Kenworth compressor pump, pulleyed it to a 1/2 hp motor ans mounted it in my garage rafters then ran a line and switch down to my tank ( an old LP tank ). Quietest compressor you will ever hear. Those truck ones are engineered to be quiet.
Old Sep 14, 2003 | 09:33 PM
Mike W's Avatar
Mike W
Important tip. The tank should be tested every so often. You can do this yourself by completely filling with water then using a grease gun to pressurize it. I don't remember the amount and I am not going to guess here. You can also get it done at a shop. I read a story about a guy that had a tank go. It blew a hole thru his wall.
Old Sep 14, 2003 | 09:53 PM
Duderoy's Avatar
Duderoy
Sounds like a painfull and messy way to check for leaks. just use soap water and spray it down. If you see small group of white bubbles, you got a leak.
Old Sep 15, 2003 | 04:10 AM
Torque1st's Avatar
Torque1st
Posting Legend
You are not testing for leaks with that test, you aree checking for structural integrity. Pressure testing is very important on an air tank. If a seam rusts out and splits the result can be just like a bomb explosion.
Other pressure tanks do not have the corrosion allowance that is built into an ASME certified tank design.
Old Sep 15, 2003 | 07:30 PM
Duderoy's Avatar
Duderoy
But you must realize, air tanks air designed to hold 300lbs of pressure. A grease gun can easily generate 3500lbs of pressure. I guess it could serve a purpose I've just never seen one do anything more than leak let alone explode like a bomb with only 150lbs of pressure and I have worked in a welding shop for 22 years now. I certainly wouldn't put more than 300 lbs with this test . I would rather see it come apart with water in it than air though.
Old Sep 15, 2003 | 10:16 PM
Torque1st's Avatar
Torque1st
Posting Legend
When a tank is pressure tested it is done with a gage and full of liquid. Even tho a grease gun can put out that kind of pressure you always watch the gage and bring it up to test pressure slowly. I do not know what the test pressure is for a given air tank tho. Some are designed for a lower working pressure than 300.
They do explode sometimes, there was a user in another thread here recently that said something about one blowing up somewhere. Usually they just die of pinhole rust thru leaks.
Old Sep 16, 2003 | 09:42 PM
Birken Vogt's Avatar
Birken Vogt
The reason they don't generally explode is that once they pinhole, they no longer hold air and so they get junked. I have been around the block a few times where every action is scrutinized for OSHA violations and anything else that might cause anything more serious than a stubbed toe but I don't think I have ever seen a recommendation to hydro air tanks.
Birken
