Travellers Oil
Old Dec 28, 2017 | 04:24 PM
jcrammell's Avatar
jcrammell
Travellers Oil
I searched the forum but couldn't find anything.
I was at Tractor Supply today and saw they carry an oil called Travellers. It is way cheaper than the Rotella that I currently use.
Anybody on here use Travellers? If so how do you like it.
If this has already been posted please show me the link.
Old Dec 28, 2017 | 06:11 PM
dn29626's Avatar
dn29626
My brother uses it in his diesel tractors.
I don't know that it meets specs for our trucks.
Old Dec 28, 2017 | 09:11 PM
Jesser02EX's Avatar
Jesser02EX
When the CK-4 spec was being discussed, someone posted a link to Ford’s “Approved “ oil and Travellers was listed as approved.
i haven’t tried it myself, but for the cost, it’d be nice to have some in back up should I need it.
Old Dec 28, 2017 | 09:25 PM
ford390gashog's Avatar
ford390gashog
Its API approved and mostly made by WPP. Its a mid range oil with decent TBN and good flash point. But the HT/HS is on the lower side. I would keep it under 5k when used with a HEUI system. I use a ton of it and have for a long time in lots of equipment and no failures. Also most tractor supply stores are clearancing out the 2.5 gallon jugs for 11.99 if you can find them​​​​. I picked up the 12 I could find local.
Old Dec 28, 2017 | 10:31 PM
BBslider001's Avatar
BBslider001
A friend on here uses it in his OBS 7.3 with really good results. I think you could try it and see how the truck idles/runs. If all is good, go with it. My experience has been that the truck will tell you if it likes it or not. It's a good oil, but the 7.3 can be picky at times.
Old Dec 29, 2017 | 09:43 AM
akcooper9's Avatar
akcooper9
I run it with no issues
Old Dec 29, 2017 | 01:51 PM
Oldanvilyoungsmith's Avatar
Oldanvilyoungsmith
I've been using travellers since my last oil change (fixing to do another one soon). And have had no issues with it. I haven't sent any for analysis though, so I can't offer much technical insight. However I've been happy, and the truck has been happy with it.
I had 2 reasons for switching to travellers oil.
#1. It's on the Ford approved list (if it's not already posted, I can find the link tonight), and the other diesel oils sold at my tsc weren't on the list.
#2. My wife works at tsc, so I get a discount on the oil, now if only they sold the motorcraft filter...
Old Dec 29, 2017 | 02:47 PM
00t444e's Avatar
00t444e
Rural king has the Harvest King brand oil for $7 a gallon, I wouldn't be suprised if it is made by the same company as Travelers. I wouldn't hesitate to use it as long as you change it every 5K and use a good filter. All engine oils have to meet certain specs before they are allowed to be sold to the public.
Old Dec 29, 2017 | 07:05 PM
BBslider001
This is the oil my truck ran like crap on, and I mean like right away. I wish I could have used it. It's very affordable.
Old Dec 29, 2017 | 07:59 PM
Colorado350's Avatar
Colorado350
The Motorcraft filter at Walmart is $9.
Old Dec 29, 2017 | 08:43 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I've been using Travellers for years. I buy it in 5 gal buckets. Have sent several samples off and they always come back good. Ran one change to 10k on Blackstones recommendations. Currently running 7-8k between changes.
Old Dec 30, 2017 | 06:56 AM
Tugly's Avatar
Tugly
I've been running synthetic every 5000 miles. If the stuff came in 5-40 to deal with winter, I could think about it.
Old Jan 5, 2018 | 08:55 AM
markd3682's Avatar
markd3682
I would never try to cheap out with engine oil. Think about it. It's your engines blood. A good synthetic is not only good for your motor it's insurance also!
Old Jan 5, 2018 | 09:18 AM
BBslider001
Um, not at all. The only benefit to synthetic over dino is that you can run it a little longer, but then you get into UOAs. It has long been proven that synthetic protects no different or better than dino. It's all marketing and nothing based on fact. An engine run on Rotella with 5k oil changes is no better for the wear than the same engine run on Mobile TD. It just costs more, but the wear effects are the same.
Old Jan 5, 2018 | 09:21 AM
Walleye Hunter's Avatar
Walleye Hunter
I believe it helps with cold weather starts as well, which is the only reason I run it. Otherwise, I believe that, for the most part, oil is oil and I buy whatever is on sale at the time when I do my cars.
