Timing Question
Old Sep 13, 2003 | 12:02 PM
rsrxc700's Avatar
rsrxc700
Timing Question
85 E350 W/ 460 DSII dist.
Am getting terrible knocking & pinging when engine is hot, at freeway speeds, when I kick it down.
Checked timing w/ vac hose disconnected and it is within spec at 8. When I put the vac hose back on timing is at 29 at idle. Is this correct/normal?
Thinking that my timing is too advanced causing the knock.
THakns!
Old Sep 14, 2003 | 01:52 AM
Superdave's Avatar
Superdave
Timing Question
It sounds like your vacuum hose for the vacuum advance diaphram is hooked to a full vacuum port.
It should be on a part throttle vacuum port. Or something that is above the throttle plates on the carburetor.
Your full advance is coming in too quick.
Drac
21
Apr 20, 2013 07:40 PM
BRay09
Oct 28, 2010 12:15 PM
dlowenst
18
Oct 11, 2006 10:14 AM
vdaily89
21
Mar 27, 2006 09:58 PM
dmacfordshot04
13
Nov 7, 2005 11:37 AM
