2006 Expedition not starting
Old Dec 27, 2017 | 05:05 PM
Bigjeffs350's Avatar
Bigjeffs350
Hope somebody can help.. My 2006 Expedition with the 5.4 won't start. I thought it was the battery so I bought a new one and installed, still no start. It will not crank. My first thought is the starter, the truck has power. I'm away now, so I'm trying to figure out the problem so as to get it fixed when I get back. Obviously I will check all the fuses as well. Thanks everybody..
Old Dec 27, 2017 | 05:23 PM
texinwa's Avatar
texinwa
You can try pushing up the gear selector into park or pull it down into neutral and try to crank it. At least you can eliminate one possibility.
If your headlights dim when you try to start I'd say it was the starter.
Old Dec 27, 2017 | 06:14 PM
Bigjeffs350
Awsome, completely forgot about that. Do you think the gear selector safety switch may cause this as well?
Old Dec 29, 2017 | 01:12 PM
Skauber's Avatar
Skauber
What is the anti theft light doing when you turn on the ignition and then try to start it? If it's flashing rapidly, it means it hasn't recognized the key, thus it won't engage the starter. Another possibility is of course the gear selector, step on the brake while pulling the gear out with the ignition on to release the gear selector lock.
Old Dec 29, 2017 | 03:50 PM
Bigjeffs350
OK, I'm back and checked the R1 starter dealt, its good. Checked the alarm, its a solid red when trying to crank, so I think that's good. Checked the gear selector, put the key in and applied the brake and was able shift and lock back into park,
When I try to start it I hear a light click, so I'm think the power is going to the starter but the starter is not engaging..
Old Dec 29, 2017 | 06:48 PM
Bigjeffs350
Well I bought a starter and after a couple of hours and some beers had the new starter installed and the truck started right up!! Thanks everybody for their input, can't go wrong here. Cheers all.
D.L. Early
2015 + Expedition & Navigator
Sep 29, 2019 09:26 AM
Andrew Grayson
Jun 20, 2013 09:34 PM
SUVman
Jul 24, 2012 02:42 PM
73strokin
Oct 28, 2007 09:21 AM
porter
Oct 24, 2004 08:38 PM
