What did you use to trim the air dam? Any did you remove those two brackets which kind of stick down(supposed to prevent cars from going under it I believe).
I put some 2” masking tape, marked a line and used an oscillating tool to cut and then a 36” belt sander to finish the edge. Yeah I removed the Prius catchers.
