Efi 460 flooding help
Old Dec 24, 2017 | 09:24 PM
william16339's Avatar
william16339
hey guys I have a 1994 Ford F3 50 with the EFI f460 in it. The issue with the truck is it will start and run and within three minutes start to smell like raw fuel and dumps gas. Certain spark plugs are soaked with raw gas. I changed the fuel filter. Fuel pressure regulator. Egr. Tonite I just took the injectors out and cleaned them by putting 40 psi of fuel to them with a 12 volt reference so I know they work. The throttle position is with in spec. Along with the aic.
Old Dec 24, 2017 | 09:25 PM
william16339
Just need an idea of what else it could be besides a fired computer. Any help will be apriciate thabk you.
Old Dec 25, 2017 | 09:40 PM
mrollings53's Avatar
mrollings53
You check the codes?
Old Jan 17, 2018 | 08:02 PM
ExPACamper's Avatar
ExPACamper
Take a look at this thread: https://www.ford-trucks.com/forums/1...in-solved.html
Likely you'll find some answers there. Sorry for the slow reply
Old Jan 20, 2018 | 08:26 PM
wtroger's Avatar
wtroger
When my 89 did that it had a code for coolant temperature sensor problem. It did not turn on a check engine light. Changed that and all was well.
Babybudistmonk
Engine Swaps
Apr 9, 2011 07:26 AM
AMSContr
May 11, 2009 05:00 AM
Gas Guzlr
Feb 4, 2009 03:46 AM
crummy trk
Jan 9, 2005 09:35 AM
