Suggestions for patching floor covering?
Old Dec 24, 2017 | 08:02 AM
DrCharles's Avatar
DrCharles
Question Suggestions for patching floor covering?
My '93 F250 has a 2" hole worn in the rubber floor covering about where the driver's right heel rests. Otherwise the floor is not cracked or otherwise worn, and I don't feel like replacing it. Or just throwing a floor mat over it and pretending it's not there
What's the best material (and adhesive) to patch the hole with? I'm thinking about contact cement, or maybe a 3M trim adhesive. Is it actually rubber, or vinyl?
thanks.
Charles
Old Dec 24, 2017 | 06:04 PM
Workingstiff's Avatar
Workingstiff
A tube of black rtv? Black caulk?
Old Dec 24, 2017 | 06:17 PM
DrCharles's Avatar
DrCharles
Thanks, but black RTV would look funny on a red floor
I suppose I could glop something in there and try and smooth it, but that never seems to look "neat".
Old Dec 24, 2017 | 07:24 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
Pictures would help. I would suggest some flex tape on the bottom then tape off the heel pad and spray it with flex seal. Will look better, fill the hole and you can add more later of needed.
Old Dec 25, 2017 | 07:07 AM
'89F2urd's Avatar
'89F2urd
Go to the jy and cut out a section of vinyl from a truck that has the same interior. Melt it, glue it, or whatever you prefer to get it to stay.
Old Dec 25, 2017 | 07:42 PM
Diesel_Brad's Avatar
Diesel_Brad
Seriously?
A NEW vinyl floor is about $150
Old Dec 25, 2017 | 07:52 PM
DrCharles's Avatar
DrCharles
Seriously.
I don't feel like removing the bench seat and any other trim that needs to come off. It's the only worn spot and I see it whenever I get in. Lots of other things to fix before this, too.
Old Dec 26, 2017 | 04:25 AM
Diesel_Brad
Originally Posted by DrCharles
Seriously.
It is going to take FAR longer to remove 4 seat bolts and a couple screws that is it to do a half assed "repair"
Old Dec 26, 2017 | 07:48 AM
DrCharles's Avatar
DrCharles
Thanks. Your vote to just replace the floor is duly noted.
beartracks
Aftermarket Products
Dec 11, 2017 02:13 PM
djm1204
Jan 20, 2015 12:12 PM
dmtinvestments
Jun 14, 2011 01:59 PM
kermmydog
All Things Towing
Apr 18, 2010 10:33 PM
ryaneverk2
Sep 26, 2005 02:11 AM
