Sponsored by: Real Truck
2010 F250
Old Dec 24, 2017 | 05:42 AM
jt17's Avatar
jt17
2010 F250
Does this truck look right? Why does the left front wheel sit so far back in the wheel well?
Old Dec 24, 2017 | 07:14 AM
cangim's Avatar
cangim
No it doesn’t. What i cannot tell is if the wheel is turned to the left. If it is and has a spacer behind it, it would look like that.
Old Dec 24, 2017 | 07:24 AM
jt17's Avatar
jt17
yes the wheel is turned to the left. What is the 'spacer' you referenced? Thanks for the reply
Old Dec 24, 2017 | 07:33 AM
senix's Avatar
senix
it has a bit of a lift I think and a spacer would allow for bigger tires/rims, but the rims look stock to me.
Old Dec 24, 2017 | 10:45 AM
Pocketlint's Avatar
Pocketlint
I would also bet that there were bigger tires and rims on the truck but the owner opted to not sell these with the truck because maybe they put them on a new SD or they sold them separate.
I would ask the owner that very question, and if you interested in the truck you can always take it to an alignment shop and they will tell you right away if that is from a lift or if this truck was in a fender bender an the axle or frame was bent
Old Dec 25, 2017 | 02:01 PM
jt17's Avatar
jt17
What do I need to look for to tell if the truck has a lift installed? Does a truck have less stability while towing if lifted? Thanks
Old Dec 25, 2017 | 03:33 PM
senix's Avatar
senix
it can, depending on tires and stabilizers it might feel squirmy.
Amish Ford
Feb 27, 2015 12:21 PM
sturgial
Jan 3, 2014 09:38 AM
NV250
Jul 19, 2009 07:06 AM
liquid 1
1997 - 2003 F150
Mar 4, 2007 02:37 PM
BOOTROS
Feb 25, 2005 01:29 PM
