1955 F100 wiring issues need help
#46
Hooker that looks good are you routing the power switch 12 volt and returning it to the sixth wire on the turn signal switch? IS your brake cylinder in the. Stock position or are you using the firewall power brake booster.? Did if your brakes are in the stock configuration did you just leave the original switch in place or plug it. Your bracket looks easy to fix. Thanks for your information I've got several things to do to my 1955 F'100 like I commented before my brake system needs a complete overhaul. So It's probably going to involve back orders and be time consuming. Just wish I had the funds to repsir shop it out. But I question several repair shop ability to do really good work. On old vehicles. I know of one guy he is in his 90s has a shop.in Fort Worth. Several cars on the lot old shell service station. His shop.rate is pretty high. But that the only guy I know of.AJ I've been using summit racing on a few Items I've needed. Kinda planning on a new instrument panel all my gauges are really old and are boat gauges. Plastic got my fuel gauge fixed and rewired my volt meter gauge. My oil pressure and water temp are mechanical they work. I prefer a Amp meter gauge. With a shunt. AJ
So if you go that route, just take the wires off your present brake light switch and connect them to your newly installed adjustable arm style switch. About it being the 6th wire? I don't know. On a '56 stock wiring they are both Green wires. One comes from the A terminal on the headlight switch and the other Green runs to your turn signal switch. When the turn signal lever is in the middle position that Green wire feeds 12 volts from the headlight switch to both rear tail lights brake filaments, through the brake light switch when brakes are applied.
It's hard to find a mechanic who runs a good shop to work on old vehicles around here. There's a resort area not too far from me that has a shop that does that kind of work in addition to the modern car repairs. Word on the street is they are having 2nd thoughts about continuing the Classic part of it as they are getting tired of people complaining about the cost of repairs. Along with the headaches of finding parts, etc. New car, classic car, old work vehicle, some things never change! LOL!
About the Ammeter. I like them too. But pulled out the one the O.P. installed in my truck. The wiring was bad, used #12 household wire, ran through the firewall with no grommets, and I was afraid some day all that current that could potentially flow through one in the event of a fault could cause a fire. I replaced it with a voltmeter which I like better because I know what my battery voltage actually is. And with the key off it's out of the circuit.
#47
1955 F-100 6 volt to 12volt.
What brake switch do you have? If it is the one that is a low pressure unit that goes on the brake line, that could be an issue. Lots of guys have trouble with them including me. Tossed it, put an adaptor in the line and used a switch mounted to the fire wall that has an adjustable arm that touches the brake arm. If that is making sense.
everything I will need to rebuild my brake system. Found several isoated spots where my hard lines were crushed. They are steel and wondering how they got that way even noticed plyer teeth marks in a few places. My master cylinder is full of rust and pits. Could not be leave a new master cylinders cap is plastic. Made in China. I think I am going to try to find a master cylinder made in the USA. Alot and I mean alot of NAPA parts are made in China. I checked with( In Line ) and they did not have the stainless made up for my 1955 F'100. Its on order the material is made in the USA. The wheel cylinders are all made in China. Dang. AJ.
#48
Aj,
I haven't done buisness with them (yet) but a guy I know really likes Kanter Auto parts. He says they're stuff is really high quality and he has been very happy with them. If you like you could get a complete brake overhaul kit for you 55:
https://www.kanter.com/i-30560690?q=...3DFORD%20TRUCK
I see they list just the wheel cylinders at $45 each and a master cylinder at $175. I admit that sounds a little high , but if it's good quality it might be worth it. Go to their website do some shopping then give them a call.
. About the Chinese made parts. I wish I could buy only American too. But it seems hard to find or even get decent Chinese parts that USED to be made in America anymore.
#49
If cost sensitive, Rock Auto has much of the brake parts you are seeking, including wheel cylinders for under eight bucks: https://www.rockauto.com/en/catalog/...+cylinder,1952
The following users liked this post:
#50
My brake switch is similar to the one posted by hooler1. For the brake lines, it is not hard to make up your own. I did that. I borrowed a bender but you can buy them as well. Then get the fittings you need. It is a great learning experience. Don't be afraid to try it. If you don't know someone that has do it before, perhaps try asking on a local facebook or other social media group. You will be amazed how many people with hot rods are willing to help out.
#51
My 1955 brake and electrical issues
Well thanks for the reply what I ended up.doing well last week I ordered the NAPA overhaul kit. RAYBESTOS. Made in China. I got the kit last Monday. Looking at prices and decided to pull my master cylinder just to see what kinda shape it was in. No pits really looked pretty good no corrosion or the usual problems you find. I've cleaned it up. The resorvor was the worst. Lots of particles but the vent holes were clear. I soaked it in Naval Jelly. And cleaned the distribution fitting and bolt. I had an extra fitting bolt that was off my 56 maybe my 54. I owned years ago. It was in alot better shape even the seal washers were copper I heated them bright red. The Naval jelly will be done Sunday. I will take it and soak it in alcohol. And way it's worth a try to rebuild it , It's a Wagner master cylinder. AJ
olblue67
07-20-2014 06:18 PM
airharley
05-21-2008 02:47 PM
