Live axle check straps?
Old Dec 23, 2017 | 10:26 AM
JTB321's Avatar
JTB321
Now that I have the frame complete with suspension, engine trans etc I remember when I built my Factory Five Roadster that the rear axle (Fox body 8.8”) was installed with a check strap across the rear shack absorbers:
I have never seen this on any of our truck builds or even discussed. It obviously prevents over travel of the shock absorber and when the truck is jacked up the weight of the axle is on the strap not the shock itself. Any comments/thoughts?
John
Old Dec 23, 2017 | 02:24 PM
matthewq4b's Avatar
matthewq4b
Looks to be an after market coil over shock. It may very will be the shock has no internal bump stops and the axle strap is needed to limit over travel. Axel straps were used in many older vehicles such as Alfa's MG's and Landrovers.
Old Dec 23, 2017 | 03:35 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
They use them on off road 4x4's as well. Mostly on racing chassis that have long shocks and suspension travel. I don't think I've ever seen them on a street vehicle. I'm not saying they're not out there, just that I haven't seen them.
Old Dec 23, 2017 | 03:38 PM
matthewq4b's Avatar
matthewq4b
Yes they do, but they are used to limit axle articulation, primarily for rock crawlers, so not really applicable to the question posed, as why they were used in this instance.
Old Dec 23, 2017 | 06:31 PM
Mixer man's Avatar
Mixer man
From a rigger's point of view those crimped cable ends won't hold too much more than axle weight. A good strap would have looped or swaged ends and forged eyes.
Old Dec 24, 2017 | 06:40 AM
rdemilt's Avatar
rdemilt
I agree, there is little to no strength in the design of that cable. I only see it useful when changing a tire.
Old Dec 24, 2017 | 12:11 PM
JTB321's Avatar
JTB321
Thanks for the feedback, appreciate the comments on the relative strength of the crimped wire. In general though, do you believe the standard shock absorber is designed to hold the weight of the rear axle when the frame is raised?
John
Old Dec 24, 2017 | 12:24 PM
rdemilt's Avatar
rdemilt
John
Sure, I believe the shock absorber would hold the weight of the axle.
My thinking is the cable may be in place to limit downward travel of the axle, maybe to keep tension off brake lines and or cables ect.
Old Dec 24, 2017 | 01:07 PM
matthewq4b's Avatar
matthewq4b
John
Most modern shocks are designed to take full extension loading.
Until the demise of the solid rear coil spring axle in cars it was the shocks that were the limiter for axle travel. Some times even with leaf springs the shocks were the travel limiters
See below of a cut away
Old Dec 24, 2017 | 11:49 PM
Mixer man's Avatar
Mixer man
https://www.bing.com/videos/search?q...EBF8&FORM=VIRE
Old Dec 25, 2017 | 08:10 AM
JTB321's Avatar
JTB321
Just to be sure I’ll call Aldan this week to see what they advise about taking the weight of the axle on an extended shock, I’ll feedback......
EB-Larry
2015 - 2020 F150
Jan 6, 2018 09:09 AM
rootbeerford
Jun 24, 2009 02:06 PM
Gordilocks
Jan 26, 2005 01:32 PM
mjb1962
Offroad & 4x4
Apr 10, 2001 08:07 AM
mjb1962
Mar 31, 2001 10:09 PM
