zf5 Clutch issues
Old Dec 22, 2017 | 11:56 AM
pstrokemike97's Avatar
pstrokemike97
zf5 Clutch issues
I have searched these forums and other websites and havent found any straight answers. My truck has been grinding and hard shifting for awhile. New pedalbox bushings and bushing on clutch master rod. New pre bled Clutch master and slave installed. Have read things about clutch fork being bent or cracked. How do I measure clutch travel and figure out if I need a new clutch or fork. It seems to be there are many things that can cause these issues, like dropping the inspection cover and tightening bolts on the clutch can fix this. Also if this issue is caused by a bad clutch fork, can it be fixed without dropping the tranny. Please help, i cant find any answers, thanks.
Old Dec 22, 2017 | 02:17 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Does it shift like that in all gears?
Mine sounds the worst on a 4-5 upshift, but if I let the engine RPM drop to idle then make the shift around 45mph for me... it is fairly smooth without excess noise. 2-3 is pretty bad on mine when cold. 3-4 is good and 1-2 is decent.
This may sound dumb, but is the thing full of the correct fluid, being ATF? How about the shift bushings?
It cannot hurt to drop the the trans and inspect the clutch, TOB, pilot bearing, etc. There are plenty of hack 'mechanics' around and I have been fixing piles of those 'repairs' on my new to me F350.
Old Dec 22, 2017 | 02:49 PM
BuddyBarnes's Avatar
BuddyBarnes
madpogue posted this on 10-21-16 to help some one (get under the truck with a measuring tape while an assistant works the pedal. Measure fork travel at the tip. Should be 1/2" to 9/16" minimum. If it's less, trouble is "upstream" - hydraulics, pedal box bushings, arm/pushrod connection, arm orientation, etc. If there is at least minimum movement, that stuff is all okay and trouble is "downstream" - fork, throwout, pressure plate fingers, etc.) may be it will help you
Old Dec 22, 2017 | 03:00 PM
BuddyBarnes
Do you have the duel mass fly wheel ? (original clutch) or has it been changed to a single mass kit. How many miles on it?
Old Dec 22, 2017 | 03:11 PM
pstrokemike97
Just measured the clutch travel. Seems like I have 7/8 in of travel which is over spec. As far as I know it has the original dual mass clutch in it. i bought the truck with 69k and it has 75k on it now.
Old Dec 22, 2017 | 03:48 PM
BuddyBarnes
That is not a lot of mi. even on a duel mass . How much free play up and down in the peddle before the clutch starts to get some pressure? You may have to re-clock the arm for the clutch rod a bit. Someone did this just a few weeks ago. If all else is tight idk Looks like you have enough travel on the clutch release bearing arm. Someone will have some more insight
1468LP
Jun 25, 2012 01:47 PM
svcguy
Oct 8, 2010 12:33 PM
JTyler11688
Jun 18, 2010 10:04 AM
johnjx1
Oct 3, 2007 09:47 PM
sobsidian
1983 - 2012 Ranger & B-Series
Apr 30, 2004 10:03 PM
