Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2003 Escape stereo
Old Dec 21, 2017 | 07:32 PM
Ben Samways's Avatar
Ben Samways
2003 Escape stereo
So, the MACH 3 stereo in my car is only partly working -radio works (first two station buttons only), CD works but controls on that side are all dead, as well as the display being dead.
I'm thinking about a replacement, but don't have a lot to spend - would the CD-6 from, say, a 2006 work in my car?
Or another similar era Ford radio? From what I can gather, the hole isn't quite double-din - is that right?
Old Dec 22, 2017 | 09:15 PM
scott91370's Avatar
scott91370
I don't know of the other years will work but the hole is not a double din size.
Old Dec 23, 2017 | 11:25 PM
simonsi's Avatar
simonsi
OP should check, 2001 is certainly a std double-din fitting...
Old Dec 24, 2017 | 09:09 PM
scott91370's Avatar
scott91370
Crutchfield shows it's not a full double and modification is neeed to make a double fit.
Old Dec 24, 2017 | 09:31 PM
simonsi's Avatar
simonsi
Maybe Crutchfield says that but a std JVC double-din fitted straight into my 2001, 2002 is certainly the same dash, I thought 2003 was too, hence OP may need to check, suspect the metalwork is double-din, the trim may be what needs fettling.
Crutchfield is sometimes slightly off, I've been trying to use them last week to find what fits into a 2007 Toyota Yaris... :-)
Jake65
Nov 27, 2014 08:46 PM
FirstSixOh
Nov 15, 2011 11:32 PM
71'3604speed
Mar 11, 2009 07:54 PM
lockgirl
16
Feb 3, 2009 06:46 PM
ScrapperSynth
25
Sep 1, 2008 07:22 AM
