The biggest problem is you said the weight was centered BEHIND the rear axle. That turns your truck into a big fulcrum lifting the front and sagging the back. If you try it again with the weight ON or FORWARD of the rear axle it will behave very differently.
Heck, if I put 600 lbs up next to the tailgate my super duty would sag some too.
Heck, if I put 600 lbs up next to the tailgate my 97 F 250 heavy duty would sag some too.
Your tires won't prevent the sagging, moving the load forward will fix it and taking your leveling kit off will help. For what its worth my 2007 Ranger 6' bed regular cab 4wd carries 600 lbs well when you use the gray matter between your ears and load it right.
Yes I know, my old F250 also had this problem when I loaded heavy stuff behind the rear axle.
But after thinking about some of the comments here, I double checked and the door piller states that 40psi should be used tire pressure and my tires were at 40psi. Today I looked at the Goodyear Wranglers that are on this truck and they are "C" rated and recommended pressure is 50psi. Since the tires only had 40psi, that is probably why the rear end was wandering around.
I'll have to try this again (not with the current 600lbs) but I will have move another 700lbs some time in January. I'll post back with proper air pressure vs what FORD suggests.
I used to carry my Polaris RZR in the bed of the truck. That's 1200 pounds, it leveled the truck out.
That's why I laugh a bit when I see all the level kit installs. Well, duh this is what happens. Level the truck as a pavement princess and then complain when it squats when it gets used as a real truck? LOL
Are your tires "P" series? That will get you the soft side wall as comes with OE tires. I thought about it a lot when replacing the OEM tires on my 2013 F-150 4x4. Settled on LT series Goodyear Wrangler A/T Kevlar with C loading. I don't need a lot of carrying capacity although tow a 22' pontoon boat in the summer. The LT, C Load gives a lot better sidewall stiffness and is a somewhat lighter tire than the E series. Didn't get much of a gas mileage hit going with these either. All I need and the tires are wearing well, the ride is still very good. These tires are also snow rated. Seem to be good in the winter and very good in wet weather.
Lol. I used to regularly haul double that with my ranger. Drove easy peasy. Either something’s wrong with the truck or something is wrong with the...............
I have the Good Year Wrangler Fortitude on my current F150. They are a nice riding tire however I don't like them for towing, the side walls are too soft. When the time comes to replace them I'll get Good Year Wrangler Adventurer with Kevlar or Michelin LT MS2s. I'll also change out the factory shocks with Bilstein 5100's as I've done on all my F150's. Better tires and shocks make a big difference.
Those are the same tires that came with and are on my truck. The side walls are not very stiff. That's where the wandering came from.
To Frantz, the pressure recommendations that are on the door piller are just that. Tire manufactures rate their tire pressure based on the load their designed to carry. In the past I've always ran E rated tires on my F250's. Its door piller stated 55psi. The tire manufacture stated 80psi loaded. If I was running the truck empty, I kept the tire pressure @ 65psi. If I loaded the truck up, the tires ran at 80psi.
Yes I know that moving the weight forward will reduce the tail dragging, but this was a test to see what this new truck will do.
So, with all that's been said, is it probably not a good thing to be towing 5K plus weight on SL load range tires, which I believe are P-metric tires? My tires are the OEM GY Wrangler Fortitude HT, 275/65R18 116T. The load range is SL, which I'm reading may not be the best for Heavy towing? The truck is primarily our tow vehicle and is minimally used not towing. The most the truck will tow is about 8K (enclosed car hauler) with about 600# in payload. Currently, I max the psi in the truck and trailer tires when towing, fully loaded and still feel I get a little sidewall roll/flex, especially when around semi's.
The best thing I did for my truck was to get rid of those squishy Goodyear tires.
I run my load range E tires at 36-38 psi. It would ride horrible if I had them at 50 + psi, plus the center of the tread would wear out. I will air them up to around 45-50 psi in the rear when towing for any distance. I am nowhere near the max load the tire is rated for, so no need to use max inflation pressure.
Since the tires I have are rated SL, I have no clue how that's compares to a Load Range of D or E, which I understand better. Its my understanding, and the education from this and other forums, that Load Range E, provides a stiffer sidewall. I would assume with the load weight I'm towing, TW of 1K, which includes payload weight, the Load Range E might be the way to go to reduce/eliminate the roll/flex I'm getting now?
Getting rid of the squishy GY's, are there recommendations for better?
SL (standard load) tires are basically P rated tires. LT tires are just stiffer and made to haul a load continuously at its full load rating. P rated tires have to be derated by about 10% on a truck and they are not designed to operate at the full rating continuously. With LT tires on a 1/2 ton you don’t have to go with e rated tires, I run C rated which stiffens it up enough for towing and the capacity of the truck. I have run E rated tires on a 1/2 ton and didn’t notice any handling improvement towing or otherwise over the C rated tires but they were a lot stiffer riding.
E rated tires are far more numerous. C or D rated tires aren't near as common, but they are out there. I'm sure C rated tires would be fine for my uses but I wanted a slightly larger tire, which were all E rated.
