Rear Wiper issue
Old Dec 21, 2017 | 10:04 AM
inthedirt's Avatar
inthedirt
Rear Wiper issue
Wondering what brand of wiper blade everyone is using? I noticed when I first bought my Ex back in July that the rear blade doesn't effectively clean the window. Thought that the blade was old and needed replacing, but the new one is the same. Is this because of the curvature of the window itself or am I installing blades that don't flex enough? Would love to be able to actually see out of my window and not just a tiny 4in swath. Your advice is greatly appreciated!
Old Dec 21, 2017 | 11:03 AM
Greenscobie86's Avatar
Greenscobie86
Most Ford products with rear wipers have always given me less than optimal rear wiper performance no matter which blades I used... I think the design just isn't great, the wiper arms doesn't make excellent contact with the glass or whatnot.
Old Dec 21, 2017 | 11:16 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
It is the spring on the arm. It is worn out. You can replace the whole arm, or you can shorten the spring a mm or two and reinstall it.
Old Dec 21, 2017 | 11:24 AM
inthedirt's Avatar
inthedirt
Thanks, I'll look into shortening the spring a tad and "see" if that makes a difference. Sorry for the bad pun, couldn't resist!
Old Dec 21, 2017 | 03:01 PM
fordboy67's Avatar
fordboy67
Try Sure Wipe. They are "helper" springs you put on your existing arms. Takes about 15 seconds to install! surewipe.com/
Old Dec 21, 2017 | 04:34 PM
Flyboy1100's Avatar
Flyboy1100
also are wiper snuggies, i just put one on my rear wiper last week. 4.99/pr at NAPA
Old Feb 25, 2018 | 03:28 PM
lanneinbc's Avatar
lanneinbc
I came here to ask the same question. A new blade did next to nothing and I was wondering if a new arm would be in order. Going to check out Sure Wipe now
Old Feb 25, 2018 | 03:48 PM
Jeff53's Avatar
Jeff53
Type of blade
Is that a "beam" type of blade? I tried one on my Ex and I had the same problem you seem to be having. I switched back to the old style blade and it seems to be working fine now. It appears to apply more uniform pressure than the beam blades.
Old Feb 25, 2018 | 04:05 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I've had mine on since 2012 and they work great front and rear even in the worst conditions.
Old Feb 25, 2018 | 04:41 PM
Flyboy1100's Avatar
Flyboy1100
a new arm is about 37.00. its what fixed my issue.
Old Feb 25, 2018 | 05:14 PM
agsmv1's Avatar
agsmv1
Mine was new about 2 years ago, now back to the same problem. Probably a cleaning and lubrication would not hurt.
Old Feb 25, 2018 | 10:45 PM
lanneinbc's Avatar
lanneinbc
It's been a while since I bought it, but I'm pretty sure it's some type of hybrid. I have beam ones on the front, they seem to work alright if I can keep them from icing up.
Old Feb 26, 2018 | 06:47 AM
Jeff53's Avatar
Jeff53
Beam blades
I have the beam style up front and don't have a problem with them, either. But on the back, I did and changed back to the original style. It might have something to do with the shape of the glass, but I was getting the exact same effect as you with the beam on the back. It was leaving a big gap in the center that was not clean. Of course, it might be an old, weak spring in the arm, but the old standard style of blade seemed to fix it for me. Just a cheap option to try.
Old Mar 4, 2018 | 05:56 PM
lanneinbc's Avatar
lanneinbc
...unless you live in Canada! New one from local dealer is $103 - AutoNation might have a new customer.
Old Mar 4, 2018 | 09:19 PM
Flyboy1100's Avatar
Flyboy1100
thats where i got mine, granted i only live 240miles NW of their dealership so shipping was cheaper than i vould drive it
