Sponsored by: Real Truck
Spark plug torque....ANYONE ???????
Old Dec 19, 2017 | 07:57 PM
Pastor Scott's Avatar
Pastor Scott
Dear Lord I have never searched for one answer to a tech question and found so many answers...
On my 2008 5.4 what the heck is the spark plug torque spec..
Heard everything from 10lbs to 28lbs..some say dry some say never sease some say blue lock tight...PLEASE pretty please can some one tell me..
thanks...
Cant wait....please not more confussion
ps Scott
Old Dec 19, 2017 | 10:48 PM
Lawnpro979's Avatar
Lawnpro979
When i did mine i went until it felt good.....
Old Dec 20, 2017 | 01:21 AM
R&T Babich's Avatar
R&T Babich
Our older vehicles use regular style Motorcraft plugs, not sure what your 2008 uses.
I always use a torque wrench when installing steel plugs in aluminum heads.
Under 20 ft-lbs seems a bit light.
I torque our plugs to 25 ft-lbs and have had no problems with them loosening.
I change the plugs/boots at 50k and use anti-seize.
Anti-seize is used to prevent galling of aluminum when harder metals are pressured against it.
Old Dec 20, 2017 | 05:35 AM
Chuck's First Ford's Avatar
Chuck's First Ford
NEVER loc-tite... as it UNLOCKS at 265 degrees "F".. so no point.
anti-seize, 15 pound feet... call it good... YES anti-seize can act like a lube .. so 15 ,.
as it heats up.. acts like a ny-lock. but removal is still easy.
my opinion.
Old Dec 20, 2017 | 08:30 AM
redford's Avatar
redford
FTE Leadership Emeritus
Blue loctite?!
I thought the 3V Spark Plug TSB called for anti-seize on the threads (light coating, stay away from electrode), torque to 25 ft/lb and dielectric grease on the boot.
Old Dec 20, 2017 | 08:49 AM
82_F100_300Six's Avatar
82_F100_300Six
OP did you get the original ones out without breaking?
Old Dec 20, 2017 | 11:36 AM
alloro's Avatar
alloro
According the factory service manual it's 25 ft. lbs. See the last line of page 5 in the attachment.
File Type: pdf
Old Dec 20, 2017 | 12:04 PM
Diamnd1's Avatar
Diamnd1
I use anti seize and torque to 25 ft-lbs. Never had any issue.
Old Dec 20, 2017 | 05:49 PM
Pastor Scott
all plugs were changed...broke about 6...but all holes are good...but a year later many are hand loose...heard high temp loc tight by some ford dealers...also heard everything from 13lbs to 28lbs...
Old Dec 20, 2017 | 07:26 PM
Chuck's First Ford
torque.. is a measure of tightness... and plus or minus 5 pounds is not a big deal...
my choice.. is 15 with anti-seize ... but 20 ish is good also...
you might need to exceed 50 pounds to break a spark plug...
you might be over-thinking this issue... my opinion.
43 years... I have done a few.................................. thousand.
Old Dec 20, 2017 | 08:38 PM
Pastor Scott
thanks guys...going with 20 to be safe...I guess..
Old Dec 21, 2017 | 01:07 AM
R&T Babich's Avatar
R&T Babich
... .but a year later many are hand loose... ....
What were these torqued to that a year later many were hand loose?
Old Dec 21, 2017 | 01:14 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Chuck's First Ford
... 43 years... I have done a few.................................. thousand.
How many of these were in aluminum heads?
15 ft-lbs will probably hold fine for 50-60k.
The OEM #3 that blew out in my 6.8L lasted 108k, all the passenger side plugs were a bit loose.
Old Dec 21, 2017 | 06:56 AM
CollinsCD's Avatar
CollinsCD
Broke about 6???? I thought the later 5.4 engines had the new plug design that didn't break?
Old Dec 21, 2017 | 07:18 AM
Chuck's First Ford
aluminum heads are NOT NEW...
retired pro mechanic.. 43 years... many years at dealership (NOT Ford).
10 years at Honda motorcycle dealership .. aluminum heads since the 1960's..... Education is good.
the first year Honda Civic.. 1973,,, had Aluminum cylinder heads and block..
thousands are an understatement...
