F700 vin decode
Old Dec 18, 2017 | 10:25 PM
Brian Cutshaw's Avatar
Brian Cutshaw
F700 vin decode
Hey guys, can anyone decode this vin for me?
F75KU675023
Trans L
Axle D
Old Dec 19, 2017 | 07:06 AM
vze2c2gb's Avatar
vze2c2gb
Post a pic of the warranty tag
Old Dec 19, 2017 | 07:27 AM
Brian Cutshaw
Old Dec 19, 2017 | 09:43 AM
TA455HO's Avatar
TA455HO
Lead Gopher
It looks like your truck is going to fall into a 1974 time frame - You are posting in the 1961-1966 forum. You might try here.
https://www.ford-trucks.com/forums/forum38/
Chad
Old Dec 19, 2017 | 10:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by TA455HO
It looks like your truck is going to fall into a 1974 time frame.
Last 6 digits of the VIN: 675023 = 1965.
If it was a 1967/77, the first digit would be a letter followed by 5 numbers.
Old Dec 19, 2017 | 11:01 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Dyslexia strikes again! Wow, my bad....sorry about that!
Chad
Old Dec 19, 2017 | 11:09 AM
NumberDummy
Originally Posted by Brian Cutshaw
F75 = F750 (gas).
K = 361 2V FT engine.
U = Louisville KY Assembly Plant.
675023 = 1965.
156" Wheelbase.
COLOR: - *
F759 = F750 (gas), 28,000 lbs. GVWR
481A: 4 = Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl / 81A Standard Cab.
L = Clark model 2651-V1 or 2653-V1 5 Speed Direct.
-D / - Rear axle was a DSO# / D = Ford Rockwell-Timken 7,000 lbs. Capacity Front Axle.
28,000 lbs. Gross Vehicle Weight Rating.
1 6 (misstamp) should be 156 net HP @ 3,800 RPM
830316:
83 = Sold to the US Government.
0316 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchaser order, making it a Domestic Special Order.
#Two digit rear axle code omitted. This means that an optional non standard rear axle was installed, making it a Domestic Special Order.
Please ask further questions in the LARGE TRUCK forum. Most members of this forum have pickups.
Old Dec 19, 2017 | 12:30 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Well, I can't really blame him since the forum title is "1961 - 1966 F-100 & Larger F-Series Trucks".
Maybe the forum should be renamed? Maybe 1961 - 1966 F-100 thru F-350 Trucks?
Not trying to pick a fight by the way...
Old Dec 19, 2017 | 01:00 PM
NumberDummy
The LARGE TRUCK forum is relatively new, and people with 500 and larger series truck should post there, because there are more members that own like trucks then there are in this forum.
For example: Looking up brake parts for 500 and larger series trucks is completely different than looking them up for F100/350's.
F100's have one size of shoes for the front, one size for the rear. Ditto F350's. F250's have one size front/rear, but 1966 F250's could have two different sizes front/rear.
Meanwhile, 500 and larger series trucks could have FIVE different sizes of front shoes, FIVE different sizes of rear brake shoes. The axle capacities must be known to get the correct sizes.
Without this info, the people have to tear the brakes down to see what sizes they are.
Then there are the wheel cylinders...there are many different sizes and most rears have two cylinders per side.
How many members of this forum that own pickups will know any of this 500 and larger series jazz?
Old Jul 26, 2022 | 05:13 AM
Tommodz's Avatar
Tommodz
1st Gear
Mine Too!
COuld you decode this VIN for me too?
F70DVN14841
Animal1978
Mar 18, 2018 04:23 PM
Brian Cutshaw
Dec 19, 2017 11:16 AM
71 LONG BED
Nov 22, 2006 07:15 AM
