battery saver mode- start engine msg??
Old Dec 18, 2017 | 10:50 AM
tractorboy924's Avatar
tractorboy924
I have a 2012 Ford FX4 5.0. a month or so ago I put a new alternator in for some back info.
I notice now when I shut the truck off.. that I get a message on the nav display that says something about battery saver mode is kicking in and to please start engine.
I checked and I dont have the battery light on at any point. I can start the vehicle in the morning after sitting all night?? and getting no signs of a low battery or anything. I will check its voltage tonight while running??
any one seen this before?? If the battery was low and alt working ive driven enough that would have replenished it. again I will have to ensure voltage goes up when running with a meter to ensure alternator working?????
truck working fine by alternator belt is on and not getting a battery low idiot light????
Old Dec 19, 2017 | 09:49 AM
Olytlr's Avatar
Olytlr
I would charge the battery and once fully charged leave the vehicle undisturbed for 8 hours.
ubereal2's Avatar
ubereal2
I've seen this message on my 2011. It would start just fine, then one morning the truck was stone cold dead. Ended up being the battery was bad. I wanted to put the factory Motorcraft battery back in, and the local dealer was priced better than every over the counter part store that I called. So if you need a battery, check around for prices before you go over the counter.
Unk Bob
Old Dec 19, 2017 | 09:51 AM
tractorboy924
last night and charging fine. I see its the original battery so for now I put on charger and this am it was ok. no message when I got to work.
I probably with get a new battery tonight or this weekend. I agree i think battery just old and tired.
Thank you all.
Old Dec 19, 2017 | 10:08 AM
ubereal2's Avatar
ubereal2
Thank you all.
I did the same thing. Full charge, and let the truck sit. And a day or two, then the message would come back on. And now with colder weather coming in, that'll be the time that you come out to a dead battery.
Unk Bob
Old Dec 19, 2017 | 10:18 AM
Robbgt's Avatar
Robbgt
Thank you all.
After you get the new battery installed, the battery life monitor will need to reset. This is done by letting the truck sit undisturbed for 8hrs. This included opening/closing doors or locking unlocking. Usually can be done overnight.
That should prevent the message from coming up again after new battery is installed.
EDIT: Realize similar was posted above in post 2
Old Dec 19, 2017 | 01:05 PM
WXboy's Avatar
WXboy
Yep, Ford and their brilliant Battery Management System. They can take that idea, turn it sideways, and....
Old Jan 15, 2021 | 10:19 AM
Herbal's Avatar
Herbal
Did you find the fix?
Old Jan 15, 2021 | 09:12 PM
gDMJoe's Avatar
gDMJoe
Exclamation
Herbal - Did you find the fix?
*HEADS-UP*
Also ...
HINT/TIP: Put your vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Edit Signature
goldieWilson
Mar 22, 2015 07:42 PM
aviatorcal
Feb 23, 2013 09:16 AM
79F-1504x4
53
Mar 3, 2011 01:53 PM
97 RED PSD
1997 - 2003 F150
Dec 21, 2005 12:01 AM
mooktank
Nov 11, 2002 03:18 PM
