Sponsored by: Real Truck
Battery Light Issue
Old Dec 17, 2017 | 09:12 PM
rmckenna's Avatar
rmckenna
Battery Light Issue
Have a 04 F-350 that the battery light comes on every now and then while driving. I have replaced the battery and alternator and the truck seems to be charging fine. I have noticed that the dash lights are not as bright as they use to be and when I'm plowing with the truck the lights dim when I use the plow. I think it may be a ground issue but do not know where to check for this any advise. I have the 5.4 liter motor.
Old Dec 18, 2017 | 12:28 AM
Tedster9's Avatar
Tedster9
Check for loose, corroded or missing ground cables and connections to block and frame. They have to be almost perfect, even invisible corrosion will cause a huge voltage drop and hork current transfer.
Old Dec 18, 2017 | 12:34 AM
'65Ford's Avatar
'65Ford
X2, start with a good wire brushing on inside of the battery clamps.
Old Dec 18, 2017 | 03:18 AM
seville009's Avatar
seville009
Even though they’re new, test both the battery and alternator to see what’s actually being generated.
Old Dec 18, 2017 | 06:42 AM
Chuck's First Ford's Avatar
Chuck's First Ford
cable is NEW... old rusty bolts and nuts.. old rusty body parts..
WHAT about grounds... REAL Important...
power out and it MUST return .. no return.. NO WORK..its simple..
like breathing.. air in .. air out.. or your dead... same with electricity..
what about the connectors for alternator...
I so dislike warning lights..
I have a real Volt meter in my truck (not a cheap factory meter)
Old Dec 18, 2017 | 08:42 AM
Copper.Farm's Avatar
Copper.Farm
Also check the plug in connector on the alternator as a loose connection would lead to the battery light coming on.
Old Dec 18, 2017 | 02:27 PM
bcvickers's Avatar
bcvickers
I've seen the body grounds cause a similar issues that can be really frustrating.
Old Dec 18, 2017 | 07:51 PM
F350 1990's Avatar
F350 1990
This is one of those "funner" ones -- went thru the same same dance with my 2003 -- ended up ripping out the entire dash, disconnecting all harnesses then using a combination of electronics cleaner, alcohol, etc to clean connections and grounds to eliminate voltage drops (which become commonplace as vehicles age).
66with352
1997 - 2003 F150
Aug 11, 2024 10:42 PM
rhensonsr
Oct 30, 2016 08:01 AM
Fordclevor
1983 - 2012 Ranger & B-Series
Jul 30, 2016 08:30 PM
joe meadows
2004 - 2008 F150
Jun 22, 2015 01:07 PM
SealAnubis
Mar 10, 2011 10:02 AM
